SOURCE: samsung idcs 18d
got the scoop on how to change the date and time. first while handset is on hook press TRSF then dial 200 Dial 1234 the display shows enable cus prog dial 1 to enable then press TRSF To change the date and time from here out press TRSF and dial 505 the display will show : (this is an example)
old: 6010104:0047
new:WMMDDYY:HHMM
Enter the new time and date using the above format and the system will return to step 2. Verify the time and date and re enter if necessary Press TRSF to store and exit. or press SPK to store and advance to the next program.
SOURCE: recording main message
trying to recorded a different main message to phone, how do you do it?
SOURCE: Samsung iDCS 18D
Dial transfer, dial 505.
You'll be promted to enter the new date and time.
Dial transfer to save and exit.
SOURCE: Cannot set the time and
HI, i got
old: 6010104:0047
new:WMMDDYY:HHMM
next program.
Hope it helped....
Good luck..
SOURCE: How do I program buttons
Hi I have posted a video off http://www.abbeytelecom.com showing how to do the soft key programming, a tip is when programming the transfer to voicemail - it shows as VT *** ( voicemail group number).
