Watches Logo
Shawna Gonzales Peterson Posted on Feb 17, 2018
Times iron man triathalon watch: the digital works but can not get analog working. It was a new watch.
  • Billy Gallagher Jul 03, 2018
    Well I can suggest to look at this article. There you will find detailed reviews on triathlon watch. The best triathlon watch will effectively measure the swimming, running, and biking metrics. I think that Garmin Forerunner 935 is the best in this range as it has no cons.
  • Anonymous Dec 29, 2018
    There are many new edition smartwatches to take into consideration. Have a look at the blog below updated with all the latest edition top class watches best smartwatch 2019
tom join
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 06, 2019
tom join
Contributor
Level 1:
Answers
Questions
0
Helped
245
Points
6
5 Related Answers
A
Anonymous
  • Posted on Jun 24, 2007
SOURCE: Time's do not match
if you still need to do this email me on [email protected]
A
Anonymous
  • Posted on Aug 24, 2007
SOURCE: Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Anonymous
  • Posted on Apr 11, 2008
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
Ekse
  • 13435 Answers
  • Posted on Jun 10, 2008
SOURCE: Casio Wave Ceptor WVA-104H
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Anonymous
  • Posted on Sep 24, 2008
SOURCE: Getting analog part of Mossimo watch to start
FIXED!!!
As it turned out these Mossimo ANA/DIGI watches use two different batteries, one for the digital part (big) and other for the analog mechanism (small).
Have the watch serviced to change the second battery and VOILA!!!!
Enjoy!
Mivales.
Made in Costa Rica!!
Do I reuse 2 batteries for my Umbro chrono watch?
Normally the Umbro Chronograph watches having analog and digital clock works on single battery. When u put the battery inside ur digital is working fine but some times for analog hands do not move due to the loose button which is used to move the watch hands. So pull it out again and insert it agin gently till tick sound comes and u r good to go.
Let me know if ur watch is working successfully:)
Jan 27, 2017 • The Watches
Casio CPW-500H-1AV analog watch not working
That certainly wouldn't hurt - be sure you use good new batteries.
1helpful
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 • Watches
I have a Timex Ironman Triathalon Watch that has both digital and analog readout. the digital can be turned on and off. how do I do that?
on the upper right button, the start/stop button, you had to press and hold it to off. i hope i had help you.
Aug 01, 2011 • Watches
1helpful
Looking for Timex Ironman triathalon shock (analog face) manual
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Nov 25, 2010 • Watches
Digital/analog watch... analog part doesn't run
A lot of times they hide a second battery for the analog display under the larger battery used to run the digital display. Also, the 2025 may not have a full charge.
Oct 17, 2009 • Watches
I cant get the hands to move on my iron man 42 lap dual tech watch
This watch has two batteries in it, one for the digital display and one for the analog movement. Chances are you just need to replace the analog battery, which is under the larger digital battery.
Timex Ironman IControl receiver not working.
Where can I get a receiver for my iron man i control watch. Lost it.
1helpful
2answers
Digital/analog times not same/# of batteries
You need to synchronize the watch. You can find directions to do that online, but you will likely have to do this several times a year. There are so many functions that you will occasionally need to go to synchro mode to synch everything up. It freaked me out the first time I saw this too. : )
7helpful
4answers
Top The Watches Experts
vince
NOEL
NOEL
Paul Carew
Are you a The Watch Expert? Answer questions, earn points and help others
