Hamilton Beach personal blender / travel mug
Go to the breaker box look for the little red indicator on the switch flip it off then back on. if you have screw in fuses look in the little window on the screw in fuses. for the black spot unscrew the fuse and replace it that should do it.
Since your blender is designed for making smoothies, it should mix pancake batter, which is equally thick, or even lighter, considering it does not usually contain chunks of fruit. Wattage is determined by multiplying the amps by the volts, you would have to divide the 175 watts by 120 to get the amps. I suppose a power converter suitable for the country you will be traveling to would prevent any electrical problems.
Im not certain how to replace the fuse but the key to making good pancakes is to barely mix the at all. Mix them only enough to combine ingredients. Think of the blender as the opposite of what you should be doing when mixing pancakes. Also melt the butter before you add it to the pancake mixture. Good luck! :)
Try talking to the suppliers
1.800.851.8900 in the U.S. or 1.800.267.2826 in Canada
SOURCE: Chris Freytag Health Blender Travel Mug
My husband and I had the same problem until I asked him to try one more time. Instead of righty tighty it's righty loosy- like the manual says. Good Luck.
SOURCE: i was using my blender and it suddenly stoped
1 check for burned fuse .
2 often the brushes that are in contact with the inductor get worn you have to replace them ( 2 brushes).
jrico39
SOURCE: replacement jar for hamilton beach wave 50754 blender
Check out the www.goodmans.com. The company is out of Florida and they do not charge sales tax outside of Florida. They have a variety of blenders for sale as well as blender parts. I hope this will help you.
SOURCE: Hamilton beach blender cleaning - food underneath
Usually the ring on the bottom of the jar unscrews. There is a rubber gasket beween the jar and the bottom hub holding the cutters.
Make sure you reassemble it correctly.
SOURCE: HB model 52735C type B35..intructions for blender pls
I'm trying to find a replacement Blade for my Black & Decker BL675 nut i'm having a really hard time finding one... Any suggestions?
