Hamilton Beach Single-serve Personal Blender Travel Blender For Smoothies Shakes Logo
Question about Hamilton Beach Single-serve Personal Blender Travel Blender For Smoothies Shakes
Why does the liquid sometimes leak from the bottom of the cup into the base? What can I do?
Posted by Judi Monk Alicie on
johnny rebel
    Top Expert:
  • Hamilton Beach Master
  • 10,875 Answers
Tighten the base or make sure the rubber gasket is in there
Posted on May 08, 2015
Why does water leak out when filled passed the top of blade
About 11,000 results (0.81 seconds) Search Results
    [PDF]Instruction Booklet Premier™ 11-Cup Series - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-2011.pdf
    Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
    [PDF]Download Manual - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
    Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
    [PDF]Food Processor - Cuisinart
    https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
    Cuisinart
Motor leaking dark liquid
Hi, my wife and I purchased the Health master blender about 6yrs ago. I recently noticed that the liquid was leaking from the bottom of the container. The blade is totally loose. How can I tighten it if at al?
Krups blender switch lights, but motor doesn't turn
Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
kolbrun
2answers
My ninja base single serve button is always on, even with nothing attached and it can run with no attachment. I cannot use anything but the single serve.
read your owner manual section troubleshooting. However you must test the control board fro defective, but test the main switch for defective use the multimeter for continuity and replace it
God bless you
9helpful
Unable to fit. Cup into base of rocket blender
I had this exact same problem and was scratching my head why would that happen all of a sudden. After taking it completely apart (which I didn't need to), I realized in the end that the cup rim was stuck at the bottom of the blender base. It looked like a part of the base what got me confused the first place. The base of the blender is flat with no ridges around; check if this is the same problem with yours.
2helpful
2answers
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Base leaks heavily when any liquid goes in!
make sure the seal gasket is between the base and the blade base- 99% it will solve your problem!
Open Questions:
See all Hamilton Beach Single-serve Personal Blender Questions
Top Hamilton Beach Blenders Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
Are you a Hamilton Beach Blender Expert? Answer questions, earn points and help others
