There are two ways you can follow to change the password of your Cisco E3200 router. The first one is that you can directly reset your router by pressing the Reset button and then change the password by accessing the Cisco router settings online.
The second one is that you have to navigate the http://192.168.1.1 IP address in your web browser to enter your Cisco router configurations. To log into the setup page, you have to input the default username and password that is the admin if you have not yet changed them.
For the step-by-step directions to change the password on your Cisco router - you can click on the
https://storify.com/davidsem/5-steps-to-recover-the-password-of-cisco-router
The process might be slightly different, but you will be able to change the password.
Cisco Router Tech Support Phone Number 888 604 2301
A Cisco E3200 has a default IP of 192.168.1.1
Make sure you are connected to the router through an ethernet cable if you dont know the current wifi password yet.
Enter that number into your browsers address bar exactly as I had shown. It will ask you for a username and password. Usually for the E3200, the default user and pass are both " admin ", so you should be able to log in rather quick.
From there you can find the security settings and change the password which will look like WPA Key or WPA2-PSK depending on personal preference.
You should choose WPA2-PSK, as its the strongest in terms of security and cannot be hacked easily.
More Information on the E3200:
Linksys Official Support Linksys E3200 High Performance Dual Band Router...
SOURCE: cisco 857 router
You might need to reset the password. In order to do this, follow these directions:
create a new account:
set register back:
and that should let you login with bob/bob
SOURCE: password reset of cisco 2800 router
Straight from Cisco:
Password Recovery Procedure for the Cisco 2600 and 2800 Series ...
SOURCE: can i use webcam on e3200 cisco usb port ?
Hello i would say no.
Becauce need of driver.
But you can buy a IP camera ( i guess you need it for some kind of survailance ) it have its own ip address.
And you can access it from any computer.
Here is some info about that:
http://www.dlink.com/us/en/business-solutions/ip-surveillance/business-ip-cameras
Good luck
SOURCE: how can i change the password on my cisco ISB7000 series router?
CISCO/Linksys -To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: How to Recover the Password for Cisco 2900 Router
http://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-121-mainline/6130-index.html?referring_site=bodynav
this above link will explain how to reset the secret password.
You have to go into rommon mode with a console direct connect or via a pc emulating a terminal and change the configuration value which the above link explains in detail.
Currently I am studying cnna1 and this question had to be researched as part of my studies to come up with the answer for chapter 11 cnna-1 .
