What can i run with a 500 watt stanley converter
Assuming the output is 120VAC, you can only run items pulling about 4 amps. If the voltage output is 220 VAC, you can only run items pulling about 2.25 amps. Read the labels on the devices you want to use, they should list either watts or amps used.
To convert amps to watts: Current times voltage
To convert watts to amps: Watts divided by voltage
