20 Most Recent Stanley Fat Max 10 Watt Lithium Ion LED Rechargeable Spotlight Questions & Answers
Leave it on the charges as much time you can. Even though the charger indicates that is charged after 1 - 2 hours allow it to be on it as much time as you can (even 2 days). This procedures maintains the battery to be used more times.
Stanley Fat Max... | Answered on May 03, 2016
Check fuses first then test the voltage regulator.
Stanley... | Answered on Nov 09, 2017
NG consumption will be specific to the generator itself. Your best bet would be to consult the user manual, or at the very least, post the model #.
A very loose rule of thumb is that if your generator consumes 1 gallon of fuel at a certain load, it will consume 100CCF (aka 1 Therm) of NG, or 1 gallon of propane.
The numbers that you are stating are WAY above Stanly power generators, are in a class that is considered to be Commerical Equipment.
Stanley... | Answered on Jun 22, 2010
Take the plug out and go to Home Depot. Buffalo Tools makes that unit and Home Depot is a seller
Electrical... | Answered on Nov 27, 2020
In the states, a portable generator that supplies ONLY equipment mounted on the generator and/or cord and plug-connected equipment THROUGH RECEPTACLES MOUNTED ON THE GENERATOR do not require bonding to a grounding electrode.
Contact Steel Craft directly to inquire. Be sure to identify model.
You didn't say it isn't working so presumably your concern is confined to the brief appearance of the overload light...
Taking a complete guess it could be the complex electronic circuitry carrying out a self-diagnostic check in the same way car electronics do.
Electrical... | Answered on Nov 26, 2020
It could be a problem with the fuse and the circuit for the bathroom that is causing this issue to be occurring and a problem with the electricity wires and supply too and needs to be looked and inspected by an electrician to see why this is happening.
Electrical... | Answered on Nov 21, 2020
Better get someone who knows electricity. GFCI OUTLETS always need 3 wires or they will not protect. This is not time to learn about electricity from internet. Wrong connection and someone life may be in danger.
Electrical... | Answered on Nov 18, 2020
make model killowatt output?? portable or standby???
Electrical... | Answered on Nov 16, 2020
Here you go
Under the sink you tighten the nut. And if you haven't yet go ahead and insert the hose.
How to install a Garbage Disposal Button - InSinkErator ...
Electrical... | Answered on Nov 14, 2020
Stanley Fat Max 10 Watt Lithium Ion LED Rechargeable Spotlight Logo
3 questions posted
Top Stanley Electrical Supplies Experts
Sheldon Dedek
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Electrical Supplies
Most Popular Question
stanley fatmax instructions
  • Electrical Supplies
