SOURCE: Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
SOURCE: ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
SOURCE: Washing machine front loading door won't open.
that is the way it's made you have to turn it off before you can open it or water would go every where.
SOURCE: LG Tromm Front door won't unlock
I have this exact problem!!! Did anyone ever figure it out??!! HELP!!
