Cars & Trucks Logo
S
Steven Brown Posted on Aug 14, 2017
Hello again I don't know if my last question went threw my computer is given me a hard time with your web site. So after I torque the rod caps to 18 ft/pds I do not turn them a nother 90 degrees?
3answers
Looking for Hyundai hd65 cylinder head, big ends and mains torque settings
  1. Tighten the cylinder head bolts in the sequence shown. Using the 4 step torque turn method, tighten according to the following values:
    • Step 1: All to 34 Nm (25 ft. lbs.)
    • Step 2: All to 68 Nm (50 ft. lbs.)
    • Step 3: All to 68 Nm (50 ft. lbs.)
CAUTION: Do not use a torque wrench for the following step.
Step 4: Turn an additional 1/4 turn
  • Step 5: Install and tighten bolts (1-10) in sequence shown, to 41 Nm (30 ft. lbs.) .
  1. Tighten bolts (1-10) again to 41 Nm (30 ft. lbs.) PLUS 1/4 turn in sequence shown.
  2. Install main bearing bedplate to engine block bolts (11-20), and torque each bolt to 28 Nm (20 ft. lbs.) in sequence shown.
Connecting Rod Cap Bolts 54 Nm (40 ft. lbs.) + 1/4 turn
1997 Jetta: Torque settings..vw..the head, fly wheel, big ends.
1997 Jetta3 1800 feul injection
Vibration Damper/belt Pulley
Tighten 20 Nm (14.8 ft lb) Crankshaft Toothed Belt Sprocket Tighten 90 Nm (66 ft lb) + 90° Camshaft Sprocket Tighten 80 Nm (60 ft lb) Main Bearing Cap
Tighten 65 Nm (48 ft lb) FLYWHEEL TORQUE
Torque 60 Nm. (44 ft. lbs.) + 1/4 turn (90°) [1] [1] Always replace bolts.
CYLINDER HEAD TIGHTENING TORQUE [1] :
1st sequence: 40 Nm (30 ft lb)
2nd sequence: 60 Nm (43 ft lb)
Final sequence: plus 1/2 turn (180°)
Here are some additional specifications, thanks
ntake Manifold
Mounting Bolts 25 Nm (18 ft. lbs.) Bearing Cap Nut 20 Nm (15 ft. lbs.) Rod Bearing Cap
Assembly
Tighten 30 Nm (22 ft lb) + 90° To measure radial clearance
Tighten 30 Nm (22 ft lb) but NOT additional 90° TIGHTENING SPECIFICATIONS
Oil Pump Bolt 20 Nm (14 ft. lbs.) Oil Tube To Block 10 Nm (7 ft. lbs.) Exhaust Manifold to Cyl. Head 25 Nm (18 ft lb) Exhaust Manifold to Front Exhaust Pipe 40 Nm (30 ft lb) Water Pump
Cover Bolts 10 Nm (7 ft. lbs.) Mounting Bolt and Studs 20 Nm (15 ft. lbs.) + 1/4 turn (90°) Pulley Bolts 25 Nm (18 ft. lbs.)
Connecting Rod Nuts:
Tighten In Two Stages:
First Stage 30 Nm (22 ft. lbs.) Second Stage turn an additional 90°(1/4 turn)
Torque specs
Here are the torque specs you requested:
MAIN BRG CAPS= 29FT/LBS THEN TIGHTEN AN ADDITIONAL 90 DEGREES in sequence(two step process)
ROD BEARING CAPS= 18 FT/LBS
CYLINDER HEAD BOLTS= 29FT/LBS + 90 degrees + another 90 degrees in sequence from the center out ward, (3 step process).
Please let me know if you have any questions
Main /con rod torque
What are the torque specs for the rod bearings on a 2010 Camaro V6?
Connecting Rod bearing cap bolts torque to 27N~m (20 lb. ft) + 50 degrees with torque angle gauge. You my also find this web site useful. www.mifbody.com There is a bulletin for this procedure.Hope this helps, Good Luck,Randy.
I’m happy to assist further over the phone at https://www.6ya.com/expert/randall_d932ef6e01588b0f
REPLACING CYLINDERHEAD-TORQU SPEXS NEEDED
For the 12 Pointed Head Bearing Cap Sub-Assembly Bolts
Start from center bolts and tighten in a clockwise rotation working out
Step 1 all bolts 22 Nm or 16 ft lb
Step 2 all bolts 44 Nm or 32 ft lb
Step 3 all bolts 45 degrees additional clockwise rotation using an angle indicator.
Step 4 all bolts 45 degrees additional clockwise rotation using an angle indicator.
Hexagon Head Bearing Cap Sub-Assembly Bolts
1ZZ-FE Engine 18.5 Nm (14 ft.lb)
2ZZ-GE Engine 18 Nm (13 ft.lb)
Connecting rod:
1. Apply a light coat of engine oil on the threads and under the heads of theconnecting rod cap bolts.
2. Install and alternately tighten the 2 connecting rod cap bolts in several passes. Torque: 1ZZ-FE: 20 Nm (204 kgf-cm, 15 ft. lbs.) 2ZZ-GE: 30 Nm (306 kgf-cm, 22 ft. lbs.) If any of the connecting rod cap bolts does not meet the torque specification, replace the connecting rod cap bolts.
3. Retighten the cap bolts by 90 more
4. Check that the crankshaft turns smoothly.
2answers
Rod bearings torque on cap nuts do you know what it is torqued at
Hello terrychadwic
If you have the 3.3 or 3.5 engine the torque is 40 foot pounds + 1/4 turn.
Regards,
netvan
1helpful
Hello, what are the torque specs on the conrod bearing caps for the 1990 toyota 4runner V6, 3VZ-FE engine? thanks
connecting rod cap torque specs is 18 ft. lb and tighten an additional 90 degree.
hope this can help
3helpful
Need torque for a 2000 Toyota Celicia GT 1.8L
Crank Main caps Tightening Torque
Connecting rod:
1. Apply a light coat of engine oil on the threads and under the heads of the connecting rod cap bolts.
3. Retighten the cap bolts by 90° more
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
