Ovens Logo
Daniel Collins Posted on Jun 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gas valve on Vulcan oven SG4D-1 makes a chattering noise?
Dennis Boxerman
Level 3:
  • Master 1,306 Answers
  • Posted on Jun 28, 2017
Dennis Boxerman
Master
Level 3:
Answers
1306
Questions
Helped
647091
Points
2787
If it is a buzzing noise it is usually not big deal. If it is truly a chatter, I suggest replacing as the electric coil is going bad.
What is a pilot generator
Simply put, a pilot generator is a thermopile that generates millivolt power to operate a gas valve.
However, on your convection oven, yours operates on an electronic spark, which is generated by an electronic ignition control module.
Oven does not come up to Heat as Oven control denotes
It is probably the thermistor in the oven cavity top right hand corner sometimes these get scraped by sheet pans or scrape the wires
Oven doesn't turn on. pluged in indicator lights on, slight smell of gas present. seems that it's not igniting
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
1helpful
1helpful
Oven will not ignight
heatman101
Vulcan SG4D convection oven is shutting off.
http://www.vulcanhart.com/manuals/F-35626.pdf
Since you were lacking a few specifics, go to this web site and it will have the service manual on your unit.
Hope this helps
Top Vulcan Ovens Experts
Paul Carew
ADMIN Eric
ADMIN Eric
David Spradling
David Spradling
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
