SOURCE: Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
SOURCE: user manual needed for binatone ma 760 quad cordless phones
managed to find a helpline number for binatone problem solved thak you
SOURCE: BINATONE CORDLESS PHONE MA 760
you have to press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button scroll to OGM REC. record ya message after the tone then press ok when done. then scroll down the menus again (press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button) scroll to TAM ON, press ok and thats the answering machine.
SOURCE: binatone fusion 2210 - manual
you can download the manual from here as the Binatone website does not seem to hold user manuals http://www.exteradirect.co.uk/download/product/001310/Fusion2200__Fusion2210_UK.pdf
SOURCE: i need a user manual
HI,you can use this link to download to view user's manual...
user-guides.co.uk/download/user/usermanual/user-manual-download-binatone-twin-3500.html
Take care.
