Question about Binatone Lands Phones
Can you please advise where I may obtain a User Manual for Binatone iDECT Vantage 9325 Twin phone?
Posted by Glyn Davies on
  • Terry
    Terry May 05, 2020
    Several Amazon vendors seem to include a quick start quide. You may be able to email them using Amazon to request a copy of the quick start guide.
    https://www.amazon.co.uk/iDect-Vantage-C...
    https://www.shpock.com/en-gb/i/Xm5BOLrF2...
    https://www.ebay.co.uk/sch/i.html?_sop=1...
Levy Orende
Hi, Am Levy And here to show where you can find the user manual for binatone idect vantage, I will give the link to where you download or use it online either is your choice. https://www.manualslib.com/manual/537701/Binatone-Idect-Freedom-Twin.html
Posted on May 05, 2020
5 Related Answers
martin hogg
  • 157 Answers
SOURCE: user manual download
There is a link to a free ( don't you just love that word ! ) . link on the BT website : http://www.shop.bt.com/content/uni2/documentation/4cxr/019198.pdf
Enjoy !
Posted on Jan 14, 2008
Anonymous
SOURCE: iDECT V2i twin phone user manual
http://www.binatonetelecom.com/resources/0000/0146/idect_v2i_ifu_master_080409.pdf
Posted on Jan 11, 2010
ismael castillo
  • 318 Answers
SOURCE: phone instruction guide wanted
Go to this link and once there click the first result which is a manual download :
www.mcla.edu/About_MCLA/uploads/textWidget/.../NECCordless.pdf
www.usedcellphoneshop.com
Posted on May 28, 2010
Anonymous
  • 5 Answers
SOURCE: online user manual for a idect Q1i twin
There is a scan of the idect q1i manual here.
Posted on Dec 06, 2010
Testimonial: "sorry just looking through my stuff and realised i havent sent any replies but it was ok thanks"
Anonymous
  • 3 Answers
SOURCE: helllo could you please help
Hello bgryan!
The iDECT S2i seems to use the same proprietary 'operating system' as the old BT cordless DECT telephones I grew up with, and the beep is actually just a tangible confirmation that the unit has commenced charging.
To turn it off, you need to undertake the following with the phone on its default screen (i.e.: displaying the handset's name, date and time):
  • Press the right softkey (next to the 'R' key and above the end call button) to enter the telephone's menu
  • The new screen that pops up should have the text "Answer machine", with a little cassette icon
  • Press down on the square directional arrow pad located in the middle of the telephone (this key also has an [MSN-like] icon of two cartooned silouettes)
  • This should present you with the "Sound" portion of the phone's menu
  • Press the right softkey again to enter the sound sub-menu
  • Press the down arrow key on the directional arrow pad to highlight the "Tones" option
  • Press the right softkey once more to enter the tones sub-menu
  • You should be presented with the following: "Key beeps " (this "" portion of the above should be highlighted in white) and "Confirmation"
  • Scroll down using the down key to reveal the other settings - in total, these are: "Key beeps", "Confirmation", "Battery low" and "Out of range" - each having its own "" or "" option located directly below it.
  • Using the right and/or left keys on the directional keypad (these have an envelope and book sign on them, respectively, also) turn each of the "" options for all four of the above settings to "".
  • This should prevent the telephone beeping once placed back on the base to charge!
Just in case, here is a quick guide to what exactly those four settings control - should you want to selectively re-enable any of them:
"Key beeps": This setting controls both the beeps made by pressing down any key on the telephone, AS WELL AS the beep produced by the phone being returned to its base to charge. One to definitely avoid enabling.
"Confirmation": This setting controls the rather annoying beep produced every time a setting is confirmed, after changing it, or when the right softkey is pressed to "OK" the change. Again, this is one to avoid enabling!
The "Battery low" and "Out of range" settings control the beeps made when the telephone is low on battery and out of the range of its base unit/reciever respectively. If you rarely charge your phone, or use it often in the garden/more than one hundred metres away from the main base unit, it may be wise to leave these options enabled. Otherwise, I would suggest selecting the "" settings for these, as they can cause some particularly loud beeps at rather inopportune times, especially when telephoning someone late at night.
I hope this helps, and as a fixya newbie I apologise if I have provided a somwehat too comprehensive answer to your query!
Kind regards,
Ghost3203 - the purported resident iDECT S2i guru... :)
P.S.: Should anyone require a Binatone iDECT S2i manual, this is the only online-available copy - actaully produced for the British department store Marks and Spencers: http://www.binatonegps.com/_global/files/S2i%20user%20guide%20for%20UK%20M&S_080513%20v1.pdf. However, Adobe PDF Reader (or equivalent) is a prerequisite to reading the above document.
Posted on Jan 05, 2011
I require a user manual for iDect S2i digital telephone.
I believe I found a pdf of an identical phone manual.
It's not provided by Binatone who seem to have no online support for that model but there was a hidden pdf from Marks and Spencer on a Binatone related website.
I included the link to download it HERE.
From what I can tell it's identical.
Let me know if this helps...
Mar 03, 2011 | Cell Phones
I have the iDECT X1i twin - I have accidently put the keypad lock on and am unable to find my user guide. Please advise how I remove this. Thank you
Try the following: press and hold the * button on the keypad to toggle the keypad lock. (There is a small icon that looks like a padlock on the key.) This works on the later X2i model.
For the user's guide, try: http://www.binatonetelecom.com/support/user-guides . Unfortunately, my browsers aren't working through the site properly. I see the X1i on Amazon but not on the Binatone site.
I hope this helps.
Jan 15, 2011 | Cell Phones
I need a user manual for binatone twin 3500
HI,you can use this link to download to view user's manual...
user-guides.co.uk/download/user/usermanual/user-manual-download-binatone-twin-3500.html
Take care.
Oct 15, 2010 | Cell Phones
Online user manual for a idect Q1i twin
Feb 19, 2010 | Lands Phones
Binatone fusion 2210 - manual
you can download the manual from here as the Binatone website does not seem to hold user manuals http://www.exteradirect.co.uk/download/product/001310/Fusion2200__Fusion2210_UK.pdf
May 05, 2009 | Lands Phones
IDECT V2i twin phone user manual
Oct 21, 2008 | Lands Phones
Lands Phones Logo
48 people viewed this question
Top Binatone Lands Phones Experts
Marvin
Marvin
NOEL
NOEL
Ngoro
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
