Question about Binatone Lands Phones
SOURCE: Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Posted on Feb 10, 2008
SOURCE: Caller ID Light Won't Stop Blinking on Base of KX TC1713 Phone
Solved this myself simply by scrolling through all the Caller ID entries from recent calls . . .
Posted on Mar 02, 2008
SOURCE: UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 16, 2009
SOURCE: I have a Panasonic KX-TCA132E
I have a panasonic KX-TCA132Ehandset, have managed unknowling turned the ringer off and now can't turn it on again, please help?
Posted on Apr 07, 2010
SOURCE: MagicJack caller ID issue
I found this solution. It worked...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190398696713
Posted on May 24, 2010
Aug 04, 2018 | Lands Phones
May 01, 2017 | Binatone Lands Phones
Oct 26, 2016 | Binatone Lands Phones
Feb 29, 2016 | AT&T 944 Corded Phone
Jan 17, 2013 | NorStar M7310 Corded Phone
Jun 05, 2012 | Siemens Lands Phones
Sep 29, 2011 | Lands Phones
Sep 04, 2009 | Lands Phones
231 people viewed this question
