SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
SOURCE: XO Vision Bluetooth in-dash dvd player
you probably set the audio for 5-channel. In a 5-channel set up. Which it doesnt sound like you have there is a 5th speaker in the center of the dash dedicated for clear vocals. Play with surround options and i'll bet you can fix it
SOURCE: XO Vision MP3 player-problems downloading TV shows
Um hey, I have a Lyra MP3 player, I can't download videos but I have gotten music on it. When you download your music, it goes to a certain folder in your computer, it's up to you to find it. All that I did was copy/paste that to your MP3's folder. If that doesn't work I am really sorry.
Good luck,
Shannon
SOURCE: XO Vision XO-141FM 14.1 in. Car Monitor
Check that you have good ground connections.
Use DVM to check if you have 12VDC to player.
If you have no DVM, you can use small car light bulb with leads.
If bulb lits from ground and hot wires, then player is bad. Or most likely a loose connections.
[email protected]
SOURCE: everytime i take turn the car on or off the radio resets to defau
If you are losing the memory (clock and presets) on the unit, you need to make sure that the yellow wire (normally) has 12 volts AL THE TIME and the red (acc) is switched on and off with the key. The battery wire (memory consant 2 volts) is the one that retains memory.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
