<span><b>ESC Key BIOS Password removing procedure</b><br />1.
Starting with the computer fully off, turn it on by pressing and
releasing the power button. Immediately and repeatedly tap the Esc key.
The computer will display the "Password = " prompt.<br />2. Enter the
correct password, and press the Enter key. The computer will display
"Valid password entered, system is now starting up. Check system. Then
press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1.
releasing the power button. Immediately and repeatedly tap the F2 key.
The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5.
Press the F5 or the F6 key to navigate to the Password section. Enter
the current password at the Old Password prompt, and press Enter. At the
New Password prompt, press Enter (without typing anything into the
password field). At the Confirm Password prompt, press Enter again
(without typing anything into the password field). The password should
now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
You have to be logged in to the account, then select change password. You again have to enter the correct password and then, only then you can enter a new password. And to make sure you entered the correct password, you are asked to enter it again.
Never give any password in any website or response of a mail. Only change a password when you are 100% sure you are logged in to the correct account.
You need to reset password, open website and enter user Id and click on " forgot password" and get verification code then enter and click on verifies and get link for reset new password .
ESC Key BIOS Password removing procedure 1.
The computer will display the "Password = " prompt. 2. Enter the
press (F1) key" 3. Press the F1 key. The BIOS setup program will appear. 4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED. 5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED. F2 Key BIOS Password removing procedure 1.
The unit will display the "Password = " prompt. 2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.) 3. The BIOS setup program will appear. 4. Using the arrow keys, move to the Security tab, and to Set User Password. 5.
now be removed. 6. Press F10 to save and exit from the BIOS Setup program.
How do you mean your password? I guess you did not enter the right password, and if you think your password is correct. The follow this steps. Enter yahoomail. Click on i can't access my account. Select my password doesn't work Then click on next. Enter your Yahoo I.D and the code shown. Click next. And answer the question you been ask correctly.to verify your identity. Click on next. To reset your password. this will help you. ok
I forgot my password in rediffmail. I tried to enter many other but do not succeed. I cannot open my account because of the password now I know it but if I enter my correct password also I cannot open My accout in rediffmail
ramamoorthy
May be ur entering wrong password or id.....click on forgotten password....if u remeber ur correct mail id enter ur mail id....or u can answer the two questions and enter your date of birth.....if u enter it correctly it will let u change ur password n u can agin login using new password......hope this helps....
