SOURCE: programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
SOURCE: how to program a uniden bearcat bc 145xl 16 channel scanning radio
I'am having a problem. I do not have codes for a uniden bearcat 145 xl 16 channel, can someone help me please?
SOURCE: it quit scanning stay on one channel
You probably locked out all the banks. Look at the top of the display, you should see numbers from 1 to 10. If you don't, press 'scan', then press each key that corresponds to any missing numbers (I'm guessing that all but the number '1' are missing). As you press each key the number will reappear at the top of the display.
SOURCE: need instruction manual of Uniden Bearcat 16
A direct link to the PDF at Uniden's site is below.
http://www.uniden.com/pdf/BC340CRSom.pdf
