20 Most Recent Uniden Oceanus DSC Wham ready Fixed Mount VHF 2-Way Radio Questions & Answers
You may have a sub-channel/privacy channel activated. Unless the person/s you are trying to talk to have the same channel and code set they will not be able to hear you. Check your manual for specific instructions on how to reset it to the default.
Uniden Oceanus... | Answered on Mar 10, 2016
From the Oceanus owners manual (page 8, link below) it tells you how to choose a mounting location and complete your install.
-Steve
http://www.uniden.com/pdf/OCEANUS%20DSCom.pdf
Uniden Oceanus... | Answered on Mar 31, 2015
I realize this question has been around for a long while, but with the price of a new radio being so low, I can't imagine why anyone would be bothered with trying to source the part (spendy...) and try to repair the unit.
Welcome to the age of disposable electronics.
-Steve
The antenna is not listed as an accessory on the Uniden web site, so your best bet is to contact their Customer Service department. You can email them by following this link:
http://www.mycusthelp.net/uniden/_cs/QuestionAsk.aspx
Bill B.
Uniden Oceanus... | Answered on Nov 07, 2010
try this link and good luck.........
http://www.retrevo.com/samples/Uniden-manuals.html?cmpid=Manuals_Uniden&s_kwcid=uniden%20manual|4347054231&adsense=2257534859&gclid=CNib_Ii476ACFUpf2godCksrcw
Uniden Oceanus... | Answered on Aug 21, 2010
Typically there is an inline fuse in the power cord. It is not built into the back of the unit. If access to the back is restricted, they should have cut out the fuse and installed it near the power buss that the power cord is attached to. How was it flush mounted if you don't have access to the back of the unit? It's not possible to attach the flush mount brackets without access. It's possible that the radio is held in place using sealant. If you are sure there's no way to pull the panel, try gently prying the radio out of the hole working around the edge to break the seal.
Uniden Oceanus... | Answered on May 10, 2008
Initially, pls check/clean your antenna, mount, coaxial cable, RF connector, power leads, grounding straps.
Based on your post description, a couple of ideas:
1. Since you receive OK, chances are the antenna/cable is good. You verify though with an SWR meter;
2. Since TX light comes on, looks like the mic, PTT and coiled cord are all OK;
3. All else works but no one can hear you, you have no power output. Use an RF wattmeter with dummy load to verify that you are pushing at least 25 watts. In the absence of a power meter, the SWR would also do or even an indication of a significant current flow to the radio ( use an inline ammeter) would indicate power.
As you will note, some specialized instruments are needed. Perhaps your best bet would be to seek the services of a qualified communications technician. TMore often it is the finals or power pack that fails resulting in no TX. In some cases, it is either the RF diode or the power regulator that causes no TX. It may also be worth your while to do a full check over of your antenna system.
Hope this be of some help. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Uniden Oceanus... | Answered on Jan 02, 2008
I am having the EXACT same problem.
Uniden Radio... | Answered on May 30, 2020
It all depends on the location. Being VHF and not using a repeater or external antenna, the range is likely less than 10 miles. Using a repeater you might get 50 miles or more. If you are thinking long range communications, you really need an HF transceiver. VHF is essentially for local communications.
Uniden Radio... | Answered on Nov 10, 2019
I have Manuals with the update Sheet $14.95 each (706)270 3829
Uniden Radio... | Answered on Sep 17, 2019
Uniden Oceanus DSC Wham ready Fixed Mount VHF 2-Way Radio Logo
Popular Tags
9 questions posted
Top Uniden Radio Communications Experts
Michael Thomas
Michael Thomas
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Uniden Radio Communications
Most Popular Question
uniden vhf marine dsc series 25 watt
  • Radio Communications
