Motorcycles Logo
I have a 1997 Honda CBR 600 f3 and need the firing order
How much oil do i put in my 1997 honda cbr 600 f3 for an oil change
3.5 US quarts or 2.9 Imperial quarts 10w-40 or 20w-50 JASO MA certified motorcycle oil
My 1997 Honda Cbr f3 acts like it running out of gas
i have a '98 f3 stuntbike. they are very tempermental with air intake. make sure your air filter is clean and induction to the engine not clogged.
Does the 97 cbr 600 f3 need back pressure?
I presume you mean exhaust, if that's the case no they don't, you can fit a straight through (race pipe) and it will run ok, you may find that the midrange power drops a bit in this case you will need to have the carbs rejetted (dynojet).
2answers
96 honda cbr 600 f3
hi would be good idear to also check spark and and timing also if you just got bike give it a good service this includes fuel filter
hope this helps
Bigger tire size for a 1997 honda 600 f3
Stock is a 160/60ZR17. I run a 170/60ZR17 with no issues. That is as wide as you can go on the rear without major modification to the swingarm or rubbing the stock arm.
Oil filter
there isn't a 99 cbr 600 f3. the f3 ran from 95 thru 98
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
