SOURCE: Optiplex Gx110 Freezing on Bios Post
The only thing I can think of is there should be a jumper pin that on the mother board that resets the cmos. Unplugging the battery does not clear the cmos rom. My guess would be the cmos rom is currupted and unfortunatly you need the rom loaded before you can flash and replace it. My advice is ditch it.
SOURCE: display driver
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_P03_GX110&os=WW1&osl=en&catid=&impid=
Just put in your Operating System and click on the download link for the Video driver.
Chris
SOURCE: I NEED VGA DRIVER FOR OPTIPLEX GX110, WINDOWS 98
you might be able to get a driver on dells website if not try driver detective at www.drivershq.com
good luck
SOURCE: OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
SOURCE: how to download dell optiplex
all drive downloads for that model can be found here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PLX_PNT_P03_GX110&os=WW1&osl=en&catid=&impid=
