I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
SOURCE: How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
SOURCE: will not drain after the wash cycle, will not enter the rinse cycle
It sounds like the lid switch is bad.Does it act as if the lid is open even when closed? A common problem is that its mounting method fails (breaks off) after some time. Quick way to test is:
Find the plastic striker in the lid and under matching hole in the washer's top you should be able to find this switch. Try to operate (close) that switch with your finger or a screw driver and operate the washer while holding it down. If now it works, the switch is the culprit. Available on-line around $30.
SOURCE: Samsung J845 error SE or 5E
I found the manual! The error is '5E' and, according to the manual, the fix is to clean the filter in the bottom front of the machine. But it took a bit more to fix my machine. Here is what I had to do...
First, use a coin to remove the cover on the bottom right hand corner of the front of the machine. Then you will find two cover or plugs, one big and one small. The small one is the 'emergency drain', the big one is the 'filter'.
Pull on the emergency drain plug and you will find that it is attached to a black rubber hose. Pull this out until it is fully extended, about 15cm. Then twist the plastic plug out of the end of the of the hose. Water should run out of the hose and (eventually) drain the bowl.
If no water comes out then the hose is either kinked or blocked. If the hose is fully extended then it is probably blocked. Twist and remove the big (filter) plug. A small barrel shaped filter is attached to the back of this plug. Lots of water will probably rush out if the drain hose is blocked. Make sure the filter is clean by washing it under running water.
Remove any debris that is in the cavity. When you look into the hole where the filter goes, there is a propellor right at the back, a small hole in the bottom and a larger hole on the left side. Make sure the is no debris in any of these places. Also make sure the propellor spins freely.
I had sand and small gravel filling the small hole in the bottom of my machine. It is nearly impossible to pick this out of the hole. However, this is the hole the goes to the black rubber emergency drain hose. Mine was completely blocked with sand, etc. I scraped what I could out of the top of the hole, but couldn't get much deeper than about 10mm. So I blew (very hard) into the black hose. It took some effort but eventually the sand and stuff burst up out of the hole.
To fully flush the hole and hose, I started the machine on rinse. The water starts to go into the bowl and after a few seconds water comes rushing down the hole in the left side of the filter cavity (and out all over the floor!) this also lets water go down the hole to the drain hose. I blew into the hose again a couple more times and the water bubbled up out of the hole and it flushed out the hose nicely.
The propellor was clear, but I can remember previously removing a hair pin from it, so make sure it is spinning freely and if not look for something stopping it.
Also check the hole on the left side. I found a curtain ring jammed up in there. It took sime getting out. I had to get a wire coat hanger and shape it into a hook that I could feed up the hole a little way. Then I was able to pull the curtain ring out. I could feel the ring with my finger, but couldn't get hold of it. When I got the wire hook on it, I had to pull hard to get it out, but it eventually came and (I don't think) I did any damage to the machine.
Once I had cleared everything out of the filter cavity, I made sure the water all flowed nicely. Then I put it back together and it has been working fine every day since.
I hope this helps others one day. I also have my manual again; if anyone else wants to check it out let me know.
Regards,
Greg
SOURCE: Our samsung j845 front load washing machine won't
SAME THING HAPPEND TO ME, SORRY BUT YOU NEED A NEW WATERPUMP, THEY GO ON THEM WASHERS ALL TIME. I REPLACED 2 AND HAD MY WASHER JUST OVER A YEAR. NOW ITS THE DOOR
