Refrigerators Logo
Hazel Ramsey Posted on Oct 27, 2016
Sharp R-8425LM making loud humming noise and defrost not working can you help please
It is a microwave combination
5 Related Answers
A
Anonymous
  • Posted on Apr 07, 2007
SOURCE: loud humming/no heating
ck door swicth
Anonymous
  • 518 Answers
  • Posted on Feb 10, 2008
SOURCE: LOUD HUMMING NOISE
Here's my thoughts:
Make sure it is level.
Could be some things inside the fridge vibrating against each other.
Geno
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 28, 2008
SOURCE: Microwave makes loud noise and does not heat. Smell of light burning
Chances are you have a bad magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
tiway1
Tim martin
  • 100 Answers
  • Posted on Sep 06, 2008
SOURCE: Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
Anonymous
  • 112 Answers
  • Posted on Oct 27, 2008
SOURCE: loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
Microwave is making a noise
If your microwave is making an unusual or loud humming noise, you may have a problem with the magnetron. This component is part of the high voltage circuit and provides the microwaves that generate the heat. If the magnetron is defective, it may cause a loud humming or buzzing noise.
https://www.fix.com/repair/appliance/microwave/unusual-noise/
1helpful
The overhead range Sharp microwave does turn on, however makes a loud humming noise and does Not warm anything/operate correctly.
You have a bad magnetron and diode and will need an appliance repair person to make the repair.
My r880f microwave has lost its microwave function only grill etc still works any ideas ?
It could be that the magentron has failed. Does it make a loud hum or buzzing noise when you try to use the microwave only function? If it does, chances are that the magnetron has shorted out. The replacement cost can be as high as the cost of a new oven, so it rarely makes sense to fix.
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Sharp R-7A82, buzzing/no heat
buzzinsg / humming / loud or louder than normal .is probably the mag / it has failed and the trans is making that noise . if older than 5 yrs I would replace ans the mag is 100.00 + and w / labor you have paid for a new on but have the old one .**** ..
3helpful
GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Dave
2helpful
Sharp over the range microwave, no heat when turned on an a loud humming noise
HI, there are two issues here. the Magnetron tube and the noise filter has failed.
Just to make sure of the Magnetron failure, expose the device and, check the Magnetron temp fuse located near the device. this fuse will show no continuity when tested if faulty. if it testes out ok, replace the magnetron.
1helpful
1helpful
Dead replaced fuse now makes loud noise
Yes that noise is causing your fuse to blow. Machine gun sound sounds like the High Voltage Capacitor or High voltage diode is bad. (Loud humming sound is usually a bad magnetron or bad power transformer). Most of these parts are inexpensive, except for the magnetron. But most of the repair bill is most likely going to be for labor.
Based on your model, it looks like an over the range microwave. And to fix any of these problems require the removal of the microwave from the wall. So its up to you if you want to deal with that hassle. But you also have to consider that you'll probably have a hard time trying to find a new microwave that will fit.
Top Sharp Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
