Lots of issues there
will need taking apart to find the faults and repair
some possibles
power source input low
internal circuity faults
switches
dry solder
diode faults
internal dust build up
One of Yamaha's new arranger keyboards, the PSR-S700 is the more entry-level model, but still comes with a range of impressive features:
SOURCE: Instruction manual for a Yamaha PSR 195 keyboard.
Try going to http://www.yamaha.co.jp/manual/english/index.php. There, you can try to find your owners manual for free.
SOURCE: Yamaha PSR-510 Keyboard
There is no need for a manual. It is so easy to operate because it is designed for easy opeating. If you need a manual to operate the PSR-510 then you really won't be able to operate it even after studying the manual. But here it is just in case you can by some miracle!
http://www2.yamaha.co.jp/manual/pdf/emi/english/port/PSR510E.pdf
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
SOURCE: yamaha psr s900 screen/display gone bad
MR SATISH IF YOU WANT TO SOLVE THIS PROBLEM CONTACT:9887070565,94136768(ANAND NARWAL)FROM RAJPUTANA ENTERPRISES
SOURCE: i have yamaha PSR-i425 keyboard.can i conect it
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
