Your best bet is to use the auto-search function of the remote to run through all the choices in the SAT category for the Direct TV box. I know it is more of a cable box, than a satellite box, but there are many code choices for direct TV under the satellite code listings. I think you will be out of luck for the Bose Cinewave. I am surprised that the Panasonic TV codes didn't work for you using the auto-search.
Here are the codes I have handy for Direct TV set-top boxes (SAT button) : 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216 & 217.
And for Panasonic TV's: 003, 054, 055, 062, 070, 148, 170 & 171.
And for Sony DVD's: 009 & 174.
To program your remote to the TV by entering a code, follow these steps:
- Turn on your TV.
- Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
- Press the TV button on the remote so that the LED blinks once and then remains solid red.
- Enter the first set of 3-digit codes from the list. The LED will
blink once every keypress. After the 3rd digit, the red LED will turn
off indicating that the code was recognized for the device. If the code
was not compatible, the LED will flash several times and you need to
return to step 2 to try that code again or to try the next code in the
list.
- After the LED has turned off, aim the remote at the TV and press
ON/OFF. If the device turns off, you have used the correct code and the
remote was successfully programed. If the device does not power off,
return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
- Turn on your TV.
- Press the ON/OFF button slowly and repeatedly until
the TV turns off. The LED will blink once each time you press the
ON/OFF button.
- Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
As I mentioned, try substituting SAT for the Direct TV box, and of course DVD for the Sony player.
I hope that helps.
