Engines & Components for Saturn Astra Logo
j
joe kelly Posted on May 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ii changend the timing belt engine locked up - Engines & Components for Saturn Astra
Ray Thompson
Level 2:
Habit-Forming:
New Friend:
  • Expert 77 Answers
  • Posted on May 18, 2016
Ray Thompson
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
77
Questions
0
Helped
36520
Points
217
WHEN YOU CHANGE A TIMING BELT THE TIMING MARKS ON THE CAMSHAFT AND CRANKSHAFT NEED TO BE SET UP PROPERLY - IF THEY ARE NOT SETUP PROPERLY THE ENGINE WILL NOT RUN AND THE VALVES MAY TOUCH THE TOP OF THE PISTONS AND LOCK UP THE ENGINE.
YOU MAY EVEN BEND THE VALVES.
REFER TO A WORKSHOP MANUAL FOR THE TIMING PROCEDURE.
NB: IF THE TIMING BELT IS NOT CHANGED AT THE RECOMMENDED TIME INTERVAL AND THE BELT BREAKS THIS CAN ALSO BEND THE VALVES - CAN BE A VERY EXPENSIVE FIX.
Why did it shut down at traffic light?
wow no year, ?
no engine size stated. there are 5 engines opted day one.
GM and omg Daewoo junk.? my guess 2.0L gas
the cam belt must not be run for 100k miles, are you?
it is a TUNEUP part (called a listed Service point)"critical too"
it must not jump.
but that depends on what jump means? and where eyes are looking (mid span belt or top edge of cam wheel?????????)
all cams have bias (turn one by and and feel that 1 time)
and this bias causes the belt mid span to bounce.
just a bit. (even a new car)
when you install a new belt, the belt is tensioned to a SPEC.
(just one step in many )
and if at SPEC, the bounce is minimized! (dont skip steps and win)
and if allowed to bounce too much (internal belt damage)
then it will jump a cog. and engine will then run like crap.(or boom, bent head valves.)
or worse blow up. (interference engines do that)
and sure stall. (stalling is the least of all this)
so, hang a timing light on it.
is the timing way retarded? yes, then belt has slipped.
lineup (eng)
1.4 L E-TEC I4 (petrol)
1.6 L E-TEC I4 (petrol)
1.8 L Family II I4 (petrol)
2.0 L Family II I4 (petrol) most common in USA.
2.0 L RA 420 I4 (diesel)
the 2.0L gas is INTERFERENCE, so ignoring the belt can be very very costly mistake.. as all are.....
Replacing water pump 2004 forenza...bolts are out but pump is frozen in place and have tried loosening w/ mallet and tried to turn it in place won't budge...any tricks to get the darn thing to
which of 6 engines is it? we cant ever guess this. and nobody ever post that. oddly
FSM quote: 2.0L USA, only.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative battery cable.
  3. Drain the cooling system into a suitable container and tighten the drain plug.
  4. Remove or disconnect the following:
    • Timing belt
    • Timing belt tension roller retaining bolt
    • Water pump mounting bolts
    • Water pump from engine block
    • Ring seal from the water pump
id, place wood block on the front of head.
and pry the pulley to the front, hard,
or rad out? use slide hammer to the pulley, last resort.
what engine:????? note there are two, 2 liter engines.
2004 Suzuki fortera belt diagram
which of 5+engines is it?
we can not guess that.
is it accessory belt or cam belt, cant guess that either.
at least these>?
the answer was on alldata.com USA, oops no country stated (FAIL)
and
at
https://suzukipitstopplus.com/Products/1027-2004-forenza-service-manual.aspx
all the time, every day, just look.
Timing belt setup 2005 suzuky forensa
08 Daewoo Lacetti rebuilt dodge ,ugh...
05 actual.
which engine, we have like 100000 post now , the same and not one with an engine stated. or country/
in usa, ? open hood see USA EPA sticker, it tells the engine type.
engines are options.
Car engine locked up
Do you mean the timing belt, or the serpentine belt ?
The serpentine belt could lock up the engine if one of the pulleys was froze. Sometimes the alternator or power steering pump will lock up.
But if the belt is off the engine it would have no effect.
I have a 93GT and the power windows,power seat and locks are not working. I changend the fuses.
93 gt's dont have fuses for these, they have circuit breakers. I had the same problem with my 93 Gt it ended up being a faulty alarm brain that had screwed everything up, I swapped out the alarm and it was fine after that.
2helpful
2answers
1985 ford bronco 11 has loud sqeeling noise after 15 minutes of running
sounds like you have a defective accessory drive belt or a locked up engine cooling fan clutch whioch causes the belt to slip, more so cold..
1helpful
Would anyone have the torque specks for the head bolts for a 2003 Volkswagon Golf with a 2L engine and I have the timing belt off and need to know where the timing marks are
Cylinder Head Assembly: Specifications
Torque & Tightening Sequence
Tighten cylinder head as follows:
Stage I .......................................................................................................................................................................................... 40 Nm (30 ft. lbs.)
Stage II ................................................................................................................................................................................................. 1/4 turn (90°)
Stage III ............................................................................................................................................................................................... 1/4 turn (90°)
_____________________________________________
Timing Component Alignment Marks: Locations
Caution: Incorrect removal or installation of the timing belt can result in damage to internal engine components.
- Turn crankshaft to cyl. 1 TDC (arrow) (Engine with manual transmission shown).
- Turn crankshaft to cyl. 1 TDC (arrow) (Engine with automatic transmission shown).
For complete Timing Belt Removal and Installation information: See: Timing Belt/Service and Repair
2answers
Could you please give me some guidance on fitting anew drive belt to my 318tds tourer as mine has snapped and i have no idea of the routing of new belt
BMW 318/325/M3/525/535/M5 1989-1993 Repair Information
Fig. 1: Setting the engine to tdc for cylinder 1 engine
Fig. 2: Releasing the tension on the spring for the timing belt roller engine
Fig. 3: Checking the alignment of the timing marks before installing the timing belt engine
Fig. 4: Timing belt arrangement engine
BMW recommends that the timing belt be changed every second Inspection ii, or every 4 years on cars that have low mileage. Most of the rest of the industry has timing belt changing intervals ranging from 40,000 miles to 60,000 miles. It is better to change the belt at a lower mileage than at a higher number.
The timing belt must be replaced every time the belt tensioner is loosened. Do not reinstall a used belt. Reusing a timing belt, even one with low mileage, is not worth the chance of having a belt break and damaging the engine.
Good luck.
Top Saturn Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Vehicle Part and Accessory Expert? Answer questions, earn points and help others
