2001 Mazda MPV Logo
Carlos E. Jaimez Posted on May 08, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is located the ground wire on mazda mpv 2001?
Odb2 scan tool does not comunicate with the pcm, i think that could be the problem.
ddd1409
Level 2:
Habit-Forming:
Scholar:
  • Mazda Expert 106 Answers
  • Posted on May 10, 2016
ddd1409
Mazda Expert
Level 2:
Habit-Forming:
Scholar:
Answers
106
Questions
0
Helped
51393
Points
314
Your ground wire connection for the OBD2 connector is located under the dash just below and to the right of the heater controls. More likely that you dont have power to the connector. Check the 10 amp "ROOM" fuse in under dash fuse box.
2005 Mazda MPV V6. I cant find the OBD2 port under the driver dash.
Question edited for a lot more clarity and toss in a LOAD of Caps
Question moved to model category.
Mazda Mpv LW5W OBD schematic from 17 pin to OBD2 16 ...
Mazda Forum https://www.mazdaforum.com > ... > Mazda MPV
Aug 7, 2015 - My Mpv has a 16 pin socket under the left side of the dash, kind of pointing down. The plug in you are looking at is for Mazda dealer ...
Diagnostic Connector Type Question - Mazda Forum
Nov 23, 2007
Where is OBD connector - '06 Mazda 6
Aug 29, 2010
OBD II Not Communicating - Mazda Forum
Dec 26, 2008
Location to perform an engine Diagnostic - Mazda Forum
Nov 20, 2007
More results from www.mazdaforum.com
SOLVED: Mazda mpv obd2 connector location
Fixya https://www.fixya.com > ... > MPV > 1998 Mazda MPV
Your ground wire connection for the OBD2 connector is located under the dash just below and to the right of the heater controls. More likely that you dont have ...
Pcm pinout diagrams 2001 mazda mpv lx [has a ford pcm]
replace the faulty sensor
the pcm makes no difference as ford and mazda are the same , just has a different badge on the front
1helpful
2answers
Obd2 scan tool don't comunicate with the pcm, what to do?
Carlos, see if there is a fuse blown to the OBD2 port, the obd port some time shares with other accessories/things like cigarette lighter.
Check all fuses, the OBD will not work if fuse is blown.
2helpful
2answers
Working in a mazda mpv 2001, i cant find the ignition control unit, when i look for the part on ebay they sell the part as: ECU-ECM-PCM, question: is the ignition control unit inside the ECU-ECM-PCM?
It appears from a wiring diagram that there is no ignition control module. The ignition coils' primary circuits are grounded through the PCM. And the wires to the sensors are all from the PCM.
Here is a link if you want to see all your wiring diagrams. I found the above information under System: engine; Subsystem: fuel controls.
Free wiring diagrams and TSB's for every make and model:
http://www.bbbind.com/technical.html
1helpful
Am working in a mazda mpv 2001, i think the problem is the pcm-ecu-ecm, ebay repaired for around 200 and they need the vin number, is this the only part for my van? or can i get one in the yank yard?
If you are sure the computer is the problem... remove the original one and it will have a tag on it with part numbers. Find one at a salvage yard and compare part numbers to make sure they are the same and it should work. The only thing that may cause issues is if the vehicle has a security system and a relearn/reprogram may be required
1helpful
Can anyone tell me where the camshaft sensor is on a 01 Mazda MPV mini van 2.5
W age of car..hard startn cud be a tuneup issue..bad dist cap..plug wires..fuel pressure reg or pump..git a data stream run w a factory scan tool....at a private shop only...for correctness n detail
2answers
Where is the starter on a 2001 mazda mpv, and is there anything special you have to do to take it off
It's on the side near the bottom of the engine. Follow the positive wire (red) from the battery as it goes straight to the starter.
2helpful
I need a diagram of the exhaust system on a Mazda 626
0996b43f80203328.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Component Location Chart-2000 MPV
1 PCM 2 Mass air flow (MAF)/intake air temperature (IAT) sensor 3 Throttle position (TP) sensor 4 Fuel tank pressure sensor 5 Engine coolant temperature (ECT) sensor 6 Crankshaft position (CKP) sensor 7 Camshaft position (CMP) sensor 8 Knock sensor 9 Heated oxygen sensor (HO2S) (front, LH) 10 Heated oxygen sensor (HO2S) (front, RH) 11 Heated oxygen sensor (HO2S) (rear, LH) 12 Heated oxygen sensor (HO2S) (rear, RH) 13 EGR boost sensor 14 Power steering pressure (PSP) switch 15 Main relay
0996b43f8020330c.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Component Location Chart-2001 MPV
1 PCM 2 Mass air flow (MAF)/Intake air temperature (IAT) sensor 3 Throttle position (TP) sensor 4 Engine coolant temperature (ECT) sensor 5 Crankshaft position (CKP) sensor 6 Camshaft position (CMP) sensor 7 Knock sensor 8 Heated oxygen sensor (HO2S) (front, LH) 9 Heated oxygen sensor (HO2S) (front, RH) 10 Heated oxygen sensor (HO2S) (rear, LH)* 11 Heated oxygen sensor (HO2S) (rear, RH)* 12 EGR boost sensor
0996b43f8020330f.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Component Location Chart- 2002-06 MPV
1998 MPV: 98 mazda mvp if i ground the black and red wirer a...
That wire is input 4S to the powertrain control module. I dont know if having it grounded all the time will affect the powertrain control computer but it doesnt seem to want to hurt the fuel pump circuitry itself from looking at the schematics. I'd try to ground it start it then make sure of course the relay opens when you shut it off then try to drive it to make sure the grounded pin on the PCM doesnt affect the transmission.
Top Mazda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mazda Expert? Answer questions, earn points and help others
