Cars & Trucks Logo
Posted on Mar 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Any idea what error code 18 means in a 1981 Cadillac DeVille?
The 'check engine' light keeps coming on. I checked all fluids, everything is good. I did the onboard diagnostic and code 18 pops up but then goes away. Any ideas?
Nicola Conroy
Level 3:
  • Cadillac Master 1,428 Answers
  • Posted on Sep 27, 2016
 Nicola Conroy
Cadillac Master
Level 3:
Answers
1428
Questions
Helped
715267
Points
3702
Error code 18 is - Open Crank Signal Circuit
5 Related Answers
Anonymous
  • 496 Answers
  • Posted on Jan 22, 2009
SOURCE: Check Engine light
that code definition is "Evap high purge flow fault". It means you may have a problem with the evaporative system. this system routes fuel fumes back to the fuel tank. If you want to try and clear this code, find the radio code for your car and then disconnect the battery for 30 seconds. Reconnect the battery and the check engine light should be out. You will then need the radio code to reset your car stereo. the check engine light may stay off if the condition was a transient one. If not, the light will come back on after you drive the car two drive cycles. That is: two starts, warm ups and shut downs. If the light returns, have a mechanic check it out.
Anonymous
  • 139 Answers
  • Posted on Apr 09, 2009
SOURCE: 2003 Cadillac Deville a check gas cap error appears with svc engi
put a new gas cap, those system are pres. even if
the cap look ok it maby leaking replace with a new
one it should solve your prob.
eng.ligh come on because of the gas cap
Anonymous
  • 245 Answers
  • Posted on May 01, 2009
SOURCE: check enginie light is on code that comes up is p1698 i have no idea what that means and my car seems to be ok
Here is my "take" on the P1698 code:
The P1698 code means that no digital data is being received by the powertrain controller from the transmission control module, located on the right inner fender. The manual says to check the ccd bus wires between the module and the rest of the system using the Chrysler diagnostic readout box. But if you don't have one then I think you can do the same thing by measuring for continuity (near 0 resistance) between pin 4 of its plug and pin 11 of the data link plug under the dash or pin 59 of the powertrain controller plug.
Then check the resistance between pin 43 if its plug and pin 3 of the data link connector or pin 60 of the powertrain controller plug. The powertrain controller is on the opposite side of the engine compartment on the left inner fender. These module plugs are held in place by a bolt. If the continuity between the transmission and the powertrain CCD wires checks to be ok, then according to the manual the trans controller should be replaced. You may be smart however to find an honest shop that has a code reader and let them determine for sure that it is the TCM and not the Powertrain control module (PCM) that is the fault. These modules are expensive enough that you would not want to replace the wrong one.
The other symptoms (1-3) are likely related to the problem because they are also dependent on the digital data communication bus for getting their instructions or sending their information. The passenger side window is probably not related to this, but rather a failed connection, switch or motor.
Anonymous
  • 7 Answers
  • Posted on Aug 16, 2009
SOURCE: Cadillac Deville 2000- Engine check light code P0741
If you like go ahead and let someone sell and replace your transmission but here is my suggestion! Check around and see if you can find a minor vacuum leak! This can simply be the big round hose that goes from the fuel injection to the power brake hub! This is normally a push in connector which has about a 1/2 inch hose clamped on it! If there is any kink or the connector is not in correctly a leak will occur and the transmission will shift rough as though you will be thrown out of the vehicle! Try unplugging this connector and plug it back in hard and straight and maybe you will be lucky and fix your problem. If the vacuum is correct your transmission will shift better than you have ever experienced!
Mike
  • 4383 Answers
  • Posted on May 24, 2010
SOURCE: Cadillac 1999 DeVille Battery goes dead after
You should check for voltage draws when the vehicle is off... Disconnect the negative battery termal, Pull dome light fuse,and connect a light or volt meter between the two.
common offenders are alternator diodes. These fail and cause drain.
Then you have to check, circuit by circuit, until you find the offending system.
Also, before doing anything, disconnect negative terminal and see if the battery is still fully charged after a few days...
7answers
Stalling
why not u try a different battery?
2005 cadillac deville new water pump cleaned thermostat flushed engine but it still wants to run hot. There is no water in the oil very clean oil in fact. Any ideas on what could be wrong
Keep checking the fluid level. Mine did the same thing for about 3 days and every time I checked the coolant tank it was low.
Could also be the dreaded head gasket. But 2005s were pretty good.
2001 Cadillac Deville will not move forward or reverse. Started as a problem that would clear up after it warmed up. Problem progressed (a few days later) to very hard to get in moving forward from a...
Sounds like a failing pump in the transmission or a torque converter problem. Check for any error codes (DTCs) using a code checker to see what is setting the warning. Next stop is probably a transmission shop.
What does it mean when the oil light in the 1995 Cadillac Sedandeville 4.9 comes on
It can mean one of two things. Either your oil level is too low, meaning more than 1 quart, or your pressure is too low. The first thing to do is check the oil level in the engine and top it up. If the light goes out after this then everything is okay. If the light stays on you should get the oil pressure checked with a mechanical guage to get an accurate reading.
Get this done as soon as possible. Manufacturers don't give you much room with these lights, when they come on you are very close to the engine meltdown point. Hope this helps.
My 1998 cadillac concours just gave me the code 730
This code means there has been excessive slip in the transmission, possibly due to lack of fluid.
Check the fluid level by warming up the car then check the dipstick with the engine still running.
Or....you may have a faulty vehicle speed sensor (VSS) located on the output shaft transmission casing.
2helpful
2answers
Service soon light came on on my 86 cadillac deville so i was wondering is that the same thing as a check engine light or different?
"service soon" is a reminder that it needs regular maintenance, and usually the dealer has a tool to reset that light on the dashboard, which can be expensive to buy.
If you do all the maint yourself, and you know that all the fluids have been replaced or capped off, you could cover the light with a piece of black electrical tape, then go on with your life.
10helpful
2answers
Check engine light on, 1997 cadillac Deville.PCM codes
PO135 is oxygen sensor Bank1 sensor1. PO404 is EGR.
personally, I'd pull EGR off, clean pintle good with throttle body cleaner or carb cleaner, re-install, erase codes & try it for a while & see if it code(s) come back.
10helpful
2answers
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
