Televison & Video Logo
Panthere Tremblay Posted on Feb 14, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Daenyx televiseur nd-26d est verrouiller
Bouton de control sont bloquer (verrouiller)
Level 3:
Top Expert:
  • Daenyx Master 76,851 Answers
  • Posted on Feb 14, 2016
Daenyx Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007969
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
2answers
How do i fix my steering wheel controls
The problem you're experiencing with your 2012 Suzuki Swift, where the steering wheel controls for the volume up and down buttons are not working, could be caused by a few different issues. Here are a few possible causes and solutions:
  1. Volume control module - The volume control module may be faulty and not sending the proper signals to the radio. A mechanic will need to diagnose and replace the module if necessary.
  2. Wiring issue - There could be a problem with the wiring that connects the steering wheel controls to the volume control module. A mechanic will need to check the wiring and repair any damaged or corroded wires.
  3. Audio Unit - The audio unit may be faulty and not responding to the volume control signals. A mechanic will need to diagnose and replace the audio unit if necessary.
  4. Steering wheel control buttons - The buttons themselves may be faulty and not working properly. A mechanic will need to diagnose and replace the buttons if necessary.
  5. Software issue - There could be a software issue that is preventing the volume control from working properly. A mechanic will need to diagnose and update the software as necessary.
It's important to have the vehicle inspected by a qualified mechanic to diagnose the problem and perform the necessary repairs. Some of the issues can be easy to fix, but some require more extensive repairs and knowledge of the systems.
Comment entrer dans le mode service de la hisense HA55K3300UWT?
Hisense MSD308PX LCD Television - comment entrer en mode service - comment mettre ? jour le logiciel - panneau de r?tro?clairage LED de 32 pouces
Pour acc?der au menu Factory OSD
une. Avec usine RC (t?l?commande)
1. Appuyez sur le bouton «M» et passez en mode usine. (Note1)
2. Appuyez sur le bouton «Menu» et acc?dez au menu OSD d'usine.
3. Appuyez sur le bouton «CH +» / «CH-» pour s?lectionner le menu de fonction, appuyez sur «VOL +» / «VOL-» pour acc?der au menu de fonction s?lectionn?. Appuyez sur le bouton "VOL +" / "VOL-" pour ajuster les valeurs du menu.
4. Appuyez sur le bouton «M» pour quitter le mode usine dans le menu OSD d'usine.
Lorsque la sortie TV du t?l?viseur est activ?e, l'utilisateur ne peut pas acc?der au menu OSD avec la t?l?commande d'usine
Remarque:
1. Dans le menu "Factory Menu", "Function"> "TOFAC", vous pouvez s?lectionner "M" ou "U", la valeur par d?faut ?tant "U".
- M-Means signifie que vous pouvez entrer en mode usine avec la RC d'usine ou l'utilisateur RC.
- U-Means: vous ne pouvez entrer en mode usine qu'avec la RC de l'utilisateur.
2. Le mode «M» est utilis? uniquement pour la production en usine.
Avec la t?l?commande de l'utilisateur
Allumez le t?l?viseur.
1. Appuyez sur le bouton «Menu» et appelez le menu OSD utilisateur.
2. S?lectionnez «Sound»> «Balance».
3. Appuyez sur la touche num?rique 1> 9> 6> 9 en s?quence lorsque l'?l?ment «Balance» est mis au point.
Remarque: Si n?cessaire, refaites les touches num?riques.
4. L'OSD d'usine appara?t.
Remarque: Appuyez sur le bouton veille, puis sur AC pour ?teindre et red?marrer le t?l?viseur, qui peut quitter le menu OSD d'usine.
Proc?dure de mise ? jour du firmware
Mise ? niveau avec ISP_TOOL
Connexion de mat?riel
Vous pouvez mettre ? jour le logiciel via un outil sp?cial (comme suit)
Connectez la carte de d?bogage au t?l?viseur ? l'aide de l'interface VGA ou du port RS232 (4 broches), l'autre port USB de l'ordinateur.
Installez ISP_TOOL4.5.0.4 ---- uniquement pour la premi?re mise ? jour.
1 Le logiciel est mis ? niveau par un outil de gravure - ISP_TOOL.exe
2 Recherchez le dossier dans lequel se trouve ISP_TOOL4.5.0.4
Il y a trois dossiers / fichiers dans ce dossier ensemble.
DLPORTIO.dll et FTD2XX.DLL doivent ?tre dans le m?me dossier
3 Double-cliquez sur l'ic?ne ISP_TOOL4.5.0.4, puis une fen?tre de dialogue appara?tra comme ci-dessous.
4 Cliquez sur le bouton "Config". Et puis une fen?tre de dialogue appara?tra.
Dessine sur le devant de "Use USB"
Le param?tre Type de port est USB
Le param?tre Addr de base est 0x38C
Adresse esclave ISP choisissez 0x92
Adresse esclave de d?bogage s?rie choisissez 0xB2 ,
5 Cliquez sur le bouton «Connecter» appear si appara?t la figure suivante, cela indique que l'ISP_TOOL est connect? (selon le t?l?viseur, «Type de p?riph?rique» peut ?tre diff?rent.)
Si appara?t la figure suivante , Il indique que l'ISP_TOOL n'est pas connect?. Cliquez s'il vous plait
le bouton "DisCon" et le bouton "Connect" pour se connecter.
6 Cliquez sur le bouton "Lire", choisissez le fichier de mise ? jour correct.
7 Une fois le fichier de mise ? jour s?lectionn? avec succ?s.
Cliquez sur le bouton «Auto» et choisissez les param?tres suivants.
8 Cliquez sur le bouton "Ex?cuter" et attendez la fin de la mise ? jour.
Si vous montrez un message d'erreur alors faites "Dis Con" >> "Connect", et cliquez ? nouveau sur le bouton "Ex?cuter", jusqu'? ce que la fen?tre de dialogue s'affiche.
Mise ? niveau avec le port USB
Le logiciel peut ?tre mis ? jour avec un p?riph?rique USB:
1. Copiez le fichier «* .BIN» tel que «MERGE.BIN» dans le r?pertoire racine d'un disque USB.
2. Ins?rez le disque USB dans la fente USB du t?l?viseur.
3. Appuyez sur le bouton «Menu» et appelez le menu OSD utilisateur, choisissez l'?l?ment «Canal»> «Mise ? jour du logiciel (USB)». (Note 1)
4. Appuyez sur «OK» pour afficher une bo?te de message de confirmation. Appuyez sur le bouton [?] pour s?lectionner «oui» dans la bo?te de message de confirmation, pour lancer la mise ? jour automatique.
5. Ensuite, le logiciel sera automatiquement mis ? jour, [ne pas s'?teindre pendant la mise ? jour].
6. Une fois le logiciel mis ? niveau avec succ?s, TV SET red?marre automatiquement.
Remarque:
1. Dans certains r?glages TV, l'option «Mise ? jour du logiciel (USB)» peut-?tre dans le menu «OPTION».
2. Apr?s la mise ? jour, vous devez confirmer la version du logiciel dans le "Menu Usine" et vous feriez mieux de faire un "Effacement non prot?g?" dans le "Menu Usine"
Power assign:
La puissance a seulement une sortie de + 12V_IN, les autres tensions sont converties de + 12V_IN.
une. 5Vstb est converti par N19 ? partir de + 12V_IN , 5VAIN et 5V_USB sont convertis par N43 ? partir de 5Vstb.
b. 3.3Vstb et 3.3V_mcu comme alimentation de secours pour le mode veille.
c. 3.3V_L'alimentation normale pour N5 et IC principal N46 est convertie par N3 ? partir de 5VAIN; 2.5V_Non alimentation normale pour N46 est convertie par N13 de 5VAIN; L'alimentation VDDC (1,28 V) pour le circuit int?gr? principal (tension de base) est convertie par N1 ? partir de 5 VAIN, tandis que l'alimentation N 1.8 (DDR) est convertie par N15 ? partir de 5 VAIN.
La tension d'alimentation VCC_A pour N17 (amplificateur audio) est convertie par N42 ? partir de + 12V_IN; 5V_Tuner alimentation pour Tuner est converti par N16 ? partir de + 12V; 5V_USB alimente l'interface USB.
f L'alimentation du panneau VCC pour le panneau est convertie par N14 ? partir de + 12V_IN
Signal RF
La fr?quence interm?diaire num?rique et la fr?quence interm?diaire de simulation sont trait?es par le syntoniseur (U42) ? partir du signal RF. Le flux de transport est d?modul? directement par le circuit int?gr? principal ? partir de la fr?quence interm?diaire num?rique, puis saisissez la carte PCMCIA pour d?chiffrer ult?rieurement le circuit int?gr? principal. Le signal interm?diaire de simulation qui a pass? l'amplification et le filtre ? ondes acoustiques de surface pour obtenir une fr?quence interm?diaire entre dans le circuit int?gr? principal. Apr?s traitement par le circuit int?gr? principal, le signal vid?o est ensuite trait? par la sortie SCALER du signal LVDS. Le signal audio est trait? et l'audio amplifi? aux haut-parleurs.
Processus de contr?le:
Le pouvoir
Hisense MSD308PX LCD Television how to enter service mode how to update...
2answers
HOW DO I RESYNC DAIHATSU SIRION CENTRAL LOCKING
You can get guide from many sites.. i know few
like reliable-store
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
Quel est le code de restricton de nokia 2690
Salut Vous pouvez utiliser des codes pour d?bloquer votre mobile ce qui r?duit principalement votre souche, pour obtenir les codes vous pouvez visiter ici mobil-unlocker
Ici vous s?lectionnez le pays d'o? vous introduit le mobile et le fournisseur ? laquelle votre mobile est verrouill? et d'obtenir les codes de d?verrouillage ? un co?t raisonnable.
I have a telecommande URC-4605B01 I d ont now how to programme my tv is a toshiba tank you i am from canada i read more in french but it ok in englis tank you
Salut et bienvenue a fixya.
Je peut (peut-etre) t`aider avec ce probleme mais j`aurais quelque questions auparavant;
As tu le livre ou liste de codes disponible pour ton URC-4605 ?
Toshiba est une marque tres populaire et a peu pres toute les telecommandes universel peuvent les opere.
Sauf dans certain cas comme; si ta television est un modele combine dvd our vcr ?
Tu peut aussi faire une recherche de code, voici la procedure avec ton televiseur allume.
1. presse le bouton "tv"
2. presse le bouton "setup" et tiend le jusqu`a temp que la lumiere cligne 2 fois.
3. Pointe la telecommande envers la tv et alterne entre les boutons "power" et "tv" jusqu`a ce que la tele s`eteigne.
note: si tu vas trop vite tu peut depasser le code et tu auras a recommencer, tu doit aussi avoir de la patience car tu peut avoir a presser ces 2 boutons une cinquantaine de fois ou plus.
4.Quand la tele s`eteindra tu doit mettre le code en memoire en pressant le bouton "setup" a nouveau jusqu`a ce qu`il cligne deux fois.
J`espere que ca te sera utile .
Salut et ALP
15helpful
2answers
Svp je veux le mot de passe pour débloquer
Svp je veux le mot de passe pour DEVROUILLER MON samsung GT-C3303K
Je vous demande si c"est possible le code de
Nokia codes de restriction sont utilis?es pour supprimer les restrictions ajout?es ? un t?l?phone Nokia par votre op?rateur d'origine de sorte qu'il ne fonctionne qu'avec leur r?seau. Il est ?galement connu comme un code de d?verrouillage ou d?verrouiller le mot de passe.
Vous pouvez obtenir le code de d?verrouillage par ligne .......... je vais proposer le site Unlock-Zone.com, qui fait un bon service ..... vous pouvez aborder ce site.
Samsung bloqué par opérateur
Qu'est-ce qu'un code PUK? Un code PUK (Pin Unlock Key) est nécessaire lorsque vous entrez un code PIN erroné 3 fois. Après avoir entré le code PIN erroné 3 fois, la carte sera verrouillé et vous devez obtenir un code PUK auprès de votre prestataire de service pour le déverrouiller. Que devez-vous faire si votre téléphone dit Entrez le code PUK Code? Vous pouvez recevoir des appels de code PUK de votre de fournisseur, soit en vous connectant à votre compte sans fil à mon compte; visitant notre Chat d'assistance technique ou en téléphonant au service à la clientèle. Une fois votre code PUK a été reçu, il sera nécessaire d'entrer dans votre téléphone pour définir un nouveau code PIN.
Si le mauvais code PUK est entré 10 fois d'affilée, la carte SIM devient invalide (verrouillées en permanence) et vous devrez acheter une nouvelle carte SIM. Le téléphone affichera «PUK bloqué opérateur d'appel» ci-dessous. Si votre périphérique a besoin d'PUK 2 s'il vous plaît appelez à la clientèle: soins. Pour obtenir votre code PUK, en log myWireless compte et suivez les étapes 1. Sélectionnez Téléphone & Device 2. Sélectionnez le lien Débloquer la carte SIM 3. Suivez les instructions sur le pop-up page Comment débloquer votre carte SIM Vous aurez besoin de votre téléphone dans la main afin de débloquer votre carte SIM. 1. Tout d'abord, entrez le code PUK chiffres 8, puis appuyez sur OK / Oui:. Remarque: Certains utilisateurs de téléphones Motorola devrez entrer ** 05 * si "Entrez le code PUK» n'est pas déjà affichée. Après avoir entré ** 05 *, puis entrez le code PUK chiffres 8 et appuyez sur OK. 2. Choisissez un nouveau code PIN, puis appuyez sur OK / Oui. 3. Re-entrer le code PIN, puis appuyez sur OK / Oui. 4. Si les codes ont été conclus avec succès, le téléphone est prêt à l'emploi.
J'espère que cela vous aide, ecuse mon mauvais français.
6helpful
Bonjour , nous avons un Asko D-3120 j'entend le moteur fonctionner mais rien ne se passe a l'interieur et la lumiere de la tasse avec une assiette clignote sans arrêt . J'ai essayé...
le drain est boucher et la panne de reserve est pleine d'eau solution sort le lave vaisselle de sont emplacement et enleve le panneau arriere ensuite éponge l'eau et débranche le tyau de drain place le tuyau de rain dans un sceau et demarre un cylce de rincage et verifier si il ne coule pas lors du cycle dans la panne
Jai un remote 1.5 echostar 429.718 et je veut men
Oui. Dans ton manuel ExpressV, ils expliquent en page 3-10 et les codes sont en pages suivantes.
SI tu n'as pas le manuel, voici:
Le code de Sharp sera un de ceux-ci: 628, 605, 608, 740, 526, 585, 591, 606, 607, 629
Appuyer sur le bouton TV du remote jusqu'à ce que les quatre boutons blancs allument;
Entrer le code de sharp (par exemple, 628) suivi du #. Le bouton TV clignote 3 fois.
peser sur le bouton rouge (power). La TV derait se fermer. Si ça ne fonctionne pas, réessayer avec le code suivant, 605, et ainsi de suite.
Top Daenyx Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Larry
Are you a Daenyx Televison and Video Expert? Answer questions, earn points and help others
