Nokia Ck - 7w Bluetooth Wireless Hands - Free Car Kit Logo
E
Edward Mace Posted on Dec 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the fuel relay switch located in the fuse box
Claude Kayser
Level 3:
Top Expert:
  • Nokia Master 9,098 Answers
  • Posted on Dec 28, 2015
Claude Kayser
Nokia Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5068056
Points
28436
2004 Toyota Camry LE. Where is the fuel cutoff switch located ?
Question edited for clarity and correct spelling of the model
Question moved to model category.
There isn't one, they are only in Ford vehicles.
You have a fuse and a relay for the fuel pump
Toyota Camry (XV30; 2002-2006) fuses and relays
Fuse Box Diagrams https://fuse-box.info > toyota > toyota-camry-xv30-20...
The fuse box is located in the instrument panel, behind the cover to the left of the steering wheel. The location of the fuses in the passenger compartment: ...
https://www.google.com/search?q=2004+toyota+camry+le+fuel+relay+location
Can i see a photo of a 1995 chevy lumina fuel pump relay fuse,? and where it plugs in in the box ?
Just a heads up: there is both a fuel pump relay AND a pump fuse, both are in the power distribution box. A relay is not a fuse, but a power switching device. The internal switch (called the coil side of relay) will let power pass through the relay when the coil (the "switch") is activated.
Look for locations on the underside of the fuse/relay block cover-this is the Power Distribution Center. Also, your owner's manual will show relay and fuse locations. Still no help? Ask at a dealer, a parts person should be able to get a copy of fuse/relay locations for your '95.
2008 chevy cobalt fuel shut off switch location
fuel pump relay located under hood in the fuse and relay box.look on other side of cover of the fuse and relay cover it will show fuel pump fuse and relay location.
2helpful
Where is the inertia switch located on a 2000 hyundai elantra. the electric fuel pump is not working so i thought the inertia switch might be the problem but have no manuel and dont know where to look. ...
you have a fuel pump relay located under the hood in main relay box,drivers side under hood just above the driverside fenderwell{marked relay box}make sure the gas cap is tightened you may have a blown fuse to the fuel pump,loacated in the same relay box.locations of fuses are determined on the fuse panel are also located on the driverside fuse panel,just to left of brake pedal in bos or panel.remove the panel and you will see on the fuse panel lid,the locations of the fuses. hope this helps and thank you for choosing fixya.com
23helpful
2answers
Where is fuel pump relay is location on Ford expedition 2001 4.6
It is located in the relay and Maxi fuse box under the hood near the battery, both the fuel pump fuse and relay are in this box, the fuel pump fuse is a 20Amp and is marked #10, the fuel pump relay is is marked as relay #301.
There is also a fuel pump cutoff switch (triggered by an accident exceeding 3 G's)
The fuel pump shut-off switch is
located in the passenger's foot well,
by the kick panel.
8helpful
2answers
2000 ranger fuse diagram
Fuel Pump relay switch is in the main box usually located on the drivers side Fender in a black box. According to the owner's manual in the power distribution box in the engine
compartment (Ford recommends disconnecting your battery)
Relay # 5 is the fuel pump relay , and also in the PD BOX is a 20 amp mini-fuse
for the fuel pump relay + RAP module in location # 9
( P.S. - don't forget your fuel pump inertia switch , in the right front passenger area ,
by the right front kick panel )Sometimes this gets kicked by passenger or if the car is bummed hard it could set this item to shut down fuel system. Best of Luck
15helpful
Fuel pump fuse located on 1997 gmc sierra
The fuse is actually a Relay Switch and its located in the Fuse Relay Center on the driverside of the engine compartment. The Black Box is labled Fuse Relay Center, the diagram on the cap displays which Relay is the Fuel Pump relay...the Relay switch is usually $8-$15 depending on where you shop
2answers
Trying to find the fuel pump FUSE.
There is no fuse specifically dedicated to the fuel pump on this year and model of Suburban. This Suburban is equipped with dual tanks and as such has two relay switches, primary and secondary, both of which are located at the main fuse box in the engine bay, that power up the respective fuel pumps.
The closest fuse (15A) controlling either of these relays also powers up the main control module (located beside and below the main fuse box). So, if one needs to disconnect the fuel pumps from functioning, then the only effective method is to disconnect the fuel pump relays.
1991 Honda Civic DX Location of Fuel relay switch
in the fuse box up by the firewall on the drivers side .... fuse 13 fuel injector relay is the only fuel related fuse/relay that i could locate.fuse 9 in the passenger compartment fuse box as well.... what size motor is in your car ?
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
