This switch is a very close fit, and it is rated for 20A 120VAC.
2LNA7 $11.09 / each
Grainger
I've used it on that vintage Craftsman bench grinder.
http://www.grainger.com/
SOURCE: switch and capacitor crapped out on 1/2 hp Sears bench grinder
Replacement should be simple. Just do a one for one hookup with the new part, after you unplug it first.
For a diagram go to;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=397.1949&productCategoryId=0721000&brandId=0247&modelName=CRAFTSMAN-1%2F2-H.P.-GRINDER&diagramPageId=00001&documentId=00023041&pop=flush
SOURCE: I need a replacement switch for a craftsman 1/2 HP bench grinder
this switch is no longer available from Sears, so I suggest making a wiring drawing and taking the switch to a local electrical supply house and try matching it up with a replacement. It seems to be a simple on/off type switch and I would think that you should have no problem. Let me know if you do and give me the information on the switch and I will try some other sites I know.
Testimonial: "Great solution. Yhank you. - b"
SOURCE: Looking for a on/off switch for a craftsman 8" bench grinder
Sears Craftsman is usually easy as Sears Parts Direct has diagrams and part numbers.
However your switch number 31919063033 is no longer available. I would suggest checking out online places like Digikey or Newark for a switch that will work for you. As long as the Voltage, amperage and number of poles and will fit in the space provided you should be OK.
Link to Sears Parts Direct.
Searching Model For Search Your Way 31919063 2
Link to Newark
Switches Relays 60 674 Products Found
Link to Digikey
Electronic Components
Wondering if there is a generic switch that could be used in place of the mcgill toggle switch 15a.125-277
