Apple iPad 2 Wifi 16GB Logo
C
Chaunte Wilborne Posted on Nov 15, 2015
Ipad disabled due to passcode being entered numerous times wrong now its saying connect to itunes
And even if i get it enabled again i don't know the passcode
Help. Me. To. Erase. Everything. On. My. iPad. Please. Help
Maybe you can use iOS Data Eraser to help you erase everything on your iPad. You just need to connect iPad to computer via usb cable, open the iOS Data Eraser tool. After a short time scanning, all data on iPad will be scanned out and displayed on program window Then you can preview and choose them to erase.
iOS Data Eraser Permanently Wipe out Data from iPhone iPad iPod
I have iPad two and cannot get it to swipe open it said change passcode I did and now I can't get in it
When you enter the wrong password in to your iPad 6 times in a row, you will see a message on the screen saying "iPad is locked" and recommending you to attempt it later. In the event that you attempt too often, your iPad many show the message letting you know "iPad is disabled connect with iTunes".
Try not to stress, we can work it out. So on the off chance that you overlooked iPad screen arrow password, this post will show you how to remove passcode from iPad easily.
Unless you made a backup before you overlooked your password, there isn't an approach to spare your iPhone information. You'll have to restore your gadget, which erases the greater part of your information and settings. The following guide provides you three methods to remove password from iPhone:
1. On the off chance you've adjusted with iTunes, use iTunes.
2. In case you're marked into iCloud and Find My iPhone is empowered, utilize iCloud.
3. In the event that you don't utilize iCloud and you can't match up or interface with iTunes, utilize recovery mode.
http://www.leawo.org/tutorial/how-to-remove-passcode-from-iphone.html
My 32gb Apple iPad shows it is disabled and I want to know how to fix it ?
You may have entered the wrong passcode too many times. The only way to recover this is to connect it to your PC with iTunes and restore it from a backup. You need to do this from the same computer you used to sync it to.
Forgotten passcode to apple ipad
It really depends if your iPad is locked or not.
Usually you can restore by connecting to a computer and using iTunes.
Follow this easy guide from Apple:
iOS Forgotten passcode or device disabled after entering wrong passcode
How do you enable ipad?
If you enter the wrong password six times in a row, you will be locked out forever, but you can follow these steps in this Apple article to restore your iPad. This is a security feature to keep sensitive data out of the wrong hands.
Ipad says disabled
http://support.apple.com/kb/ht1212
If you don't remember setting up a passcode on your ipad, maybe someone else did, and then entered the wrong passcode more than six times, resulting in a disabled ipad.
In the link above you will see instructions on how to deal with this problem, which pretty much boil down to connecting your ipad to itunes and restoring from a previous backup that you may have saved.
If you never created a backup, you can still reset and wipe your ipad from itunes, resulting in everything being erased, but at lease giving you back full use of your ipad.
My mini ipad says disabled how can i enable it again?
Did you mean that the iPad is disabled for many attempts of passcode? Usually, waiting for a particular time span can enable agin the iPad. But if does not enable back again even after a few hours, then consider restoring your iPad in iTunes.
4helpful
3answers
My ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
