Master
- Posted on Nov 11, 2015
Re: screen keeps flashing green-blue-red
The manual for the monitor can be found here (
Mitsubishi DiamondPoint V50LCD User Manual ) The specific Red Green Blue cycle isn't noted.
- I'd start with toggling on the on screen set-up display. if that comes up and is legible, then you know that the screen is working.
- What is your video set up to push to the V50? If it's not a supported resolution, the display may respond this way. try downgrading it something like VGA (640x480) and see if that works. (The max resolution shown in the manual is 1024 x 768, so don't go higher than that. It's also 24 bit color (8 bits each for R,G,B, so don't try to push 32 bit color to it)>
- Set the output to your primary monitor to 1024 x 768, thousands of colors. Make sure the monitor sees it OK. Now you know the first monitor and cable are OK. Now switch the cable to the V50 monitor. Do you get a signal now? Then the display works. Try putting your primary display on the second cable. Does it pick up anything now? No. Maybe a bad cable.
- You can try swapping the cable going to the V50 to go from your primary monitor output port on the computer to your primary monitor. if the primary monitor works OK, then the cable is good.
- Depending on the computer system you're on, make sure that you at least have a generic monitor driver installed for the V50 output. Ideally, get the driver for the monitor You can get the driver here (
Mitsubishi Monitor drivers ) amongst other places.
Testimonial: "I tried your suggestion and none of them worked. I bet it is not compatible with my graphic card. thanks for your help."
