Actually i have successfully played audio on my car dvd but when i wanted to watch vedio through my card it can not read....i also converted the vedio in many formats like mpeg-1,2,4 but it didn't work
Mitsubishi Electric NR-MZ50 Car Navigation System $1800 !
WHAT CAR? and YEAR<, go to MFG. web sit and get the manual first, if LOST ! IT.
What makes you think it can?>
sure hope.
WHA
open glove box and RTM? yet, unstated car.
car radio, head- in's/nAV are very dumbb(sic) as class of devices.
they only allow a limited set of formats.
you'r talking about movie file formats 100s,
The movie file, formats to try are MP4 and MKV (most common)
The manual Mz50. first. it will tell you what it supports, and no 2 car-heads work the same or have same limits,
so that means RTM read the manual then do experiments.
also some HEADs may have DRM rule limits.
that car HEAD really is not a computer, so is off topic here.
the MZ50 tuner can record to the SD card.
why not just try it.
find a small mp4 movie, and put it on the card, just 1 file
and see if you can play it,
but there are 100s of formats.
talk to Mitsubishi dealer or
try these
https://fileinfo.com/filetypes/video
It many do 1 or 2 but NEVER ALL formats.
SOURCE: COBY MP605 Videos won't play right
Bro that is not a problem, try to put the audio output to good if it was on normal the last time u converted
SOURCE: Converting Movies To Play On My Home Dvd Player
Convert video to .avi or DVD (Audio TS- Video VS) format.
Many common dvd players can play .avi files
(.avi files are very compact).
All dvd players play TS/VS format.
AVS4U is a reasonably priced (approx $50)downloadable suite of programs that can perform all the conversion tasks you need for audio & video.
SOURCE: I don´t known how watch videos on SD card - Jensen vm9512. Format
yes you can watch video
I alredy did it in my jensen
all you have to do is:
xvid avi
video codec: mpeg4
video bit rate: 887kbits/s
video size: 576x320
aspect ratio: 16:9
set this setting in total vide converter
do the convertion and that's.
SOURCE: model NWZA816 video format support
All right, the following section will show you the best way to help you with the download and conversion.
Download:
1. Download, install and launch Video Download Studio from http://www.downloadvideos-convert.com/download-videos-music.
2. Click“ add URL” button to paste the URL of the video you want to download. ( or you can play the video on YouTube and click “auto capture”, Video Download Studio will automatically capture and download the video for you.)
3. Download details will showed on the working window.
Convert:
1. Click“ convert” button on the top, you will switch to convert interface.
2. Click “add” button to load your videos to Video Download Studio
3. Click“profile” drop-down list to select MP4 format.
4. Click“ convert” button on the bottom, you will get MP4 format video in seconds.
As you can see, these simplest steps enable you to convert video. Join in and do it yourself, you will get a lot of fun.get it from http://www.downloadvideos-convert.com/download-videos-music
The SD card is mainly for photos, but you can do video.
The SD card needs to be formatted as fat 16
The video has to be profile 1.1
If you use the larger SDHC cards, they can be formatted fat 32.
It works best if you format it with the player and not your computer.
