SOURCE: 96 escort valve clearance
Gary, the 1.9L Ford engine has hydraulic lifters no valve adjustment is needed
SOURCE: what is the valve clearance in the 1993,1500cc
there is a white sticker underneath on the bottom side of your hood that should give you valve clearance specs.
SOURCE: Valve Clearance
valve clearance, with engine hot, intake valves are .005-.006 in, exhaust valves are .011 in, if engine is cold then its intake .009-.011 in and exhaust is .007. hope this helps good luck.
SOURCE: valve clearance of 12 valve engine
i do not know but give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man.
SOURCE: how to adjust valve clearance on a 1999 sunfire
There is no valve adjustment for that engine, Hydraulic lifters, You might remove the valve cover and see if you have a rocker arm loose
