2015 Mazda 3 Logo
Siddharth Kapoor Posted on Oct 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix the clock of 2015 Mazda3 which loses time
The clock on my 2015 Mazda 3 keeps getting reset every time I switch off the car. Is there a clock battery that I need to replace?
jim sharp
Level 3:
Master:
  • Mazda Master 987 Answers
  • Posted on Oct 22, 2015
jim sharp
Mazda Master
Level 3:
Master:
Answers
987
Questions
Helped
181974
Points
2541
Check your fuses, your losing full time power to the clock
Does a faulty brake switch cause slipper when wet sign to go on keep car in park and keep from starting car at times on a mazda cx5 2015?
There may be more than one switch. If not one switch controls the brake lights and the shifter lock.
1helpful
What model year transmission is compatible with a 2005 Mazda 3 sport
From Wikipedia.. "The Mazda3 or Mazda 3 (known as the Mazda Axela in Japan) is a compact car manufactured in Japan by the Mazda Motor Corporation. It was introduced in 2003 as a 2004 model, replacing the Familia/323/Proteg?. A performance-oriented version of the Mazda3 is marketed as the Mazdaspeed3 in North America, Mazdaspeed Axela in Japan and the Mazda3 MPS in Europe.
A second generation Mazda3 for the 2010 model year was unveiled in late 2008, with the sedan premiering at the Los Angeles Auto Show and the hatchback at the Bologna Auto Show. For the 2012 model year, Mazda began offering the Mazda3 with their newly developed SkyActiv technology, including a more rigid body, a new direct injection engine, and a new 6-speed transmission.[6]
The current third generation was introduced in mid-2013 as a 2014 model." My guess is the transmission from 2004 to 2009 mike be cross compatible. I would go to Autozone and ask or call the parts department at department at a local Madza dealer.
1helpful
Hi.my mazda3 2005 2.0 did not cone with a manual. second hand buy.if I look for radio code problems everyone keeps on saying to put in a new code after using the master code I should check the manual. I...
Take the Mazda straight to a Mazda dealership and they will solve your problem in no time. Or email Mazda corporation and they will email back with the instructions, like I did. We have a 2005 Mazda SP23.
2answers
Turn off radio
You should just hold the power button for 3 seconds and it should power off.
1helpful
Once of my headlights keeps burning out on my 2005 Mazda 3 and it is annoying, anyone can shed some light on this issue?
dear,
when a particular connector is loose or is not tighten to fix tightly in the socket it will create heat and will burn off.
try to put a new socket and tighten it so that it may not heat up.
thanx
1helpful
How to reset the pressure monitoring system warning light on Mazda 3
Read the manual on the mazda site... it's very helpful. Have you changed tires recently? have a spare on?
"After adjusting the tire air pressures, it may
require some time for the TPMS warning
light to go out. If the TPMS warning light
remains illuminated, drive the vehicle at a
speed of at least 25 km/h (16 mph) for 10
minutes, and then verify that it goes out."
Might help...
Moisture inside
HI,AS CAR IS SO NEW ,TAKE CAR BACK TO DEALER,MAY HAVE WATER IGRESS WHEN IT RAINS,THANKS.
2helpful
Clock loses time
www.finishlineperformance.com/pdf/mazda3/bulletin/09-012-06-1548.pdf
Top Mazda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mazda Expert? Answer questions, earn points and help others
