I'm pretty technical, I use to do tech support for computers, but my surround sound speakers aren't working properly. What could be wrong?
I have a RCA HTS-1000 dvd/receiver combo surround sound system. I connected it to my Vizio tv with the yellow/red/white cables. Left front speaker gets no sound during sound test or in any mode for this unit. Plugged speaker in different port, sound tested fine, plugged another speaker into the left front port, no sound. All other speakers past sound test. Watching a dvd, no sound from left front and sub. In AV-in mode, only right front and sub have sound. I've checked all the settings on my HTS and my Vizio TV according to all the info I could find. Turned speakers up on the system via the remote. Still same result.
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Hi,here is the basic info for your question.. Take care and please Remember to rate/vote and give me 4 Thumbs Up for Helping out the Community :) Hope this helps! *****************************************
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your home theater sound or multi-channel music listening experience. In particular, a correctly set time delay setting between the different channels is essential for a realistic and unified surround soundfield. Luckily, most of today's surround processors make setting the time delays between the rear and the fronts a matter of a few entries in the setup menu. Yet having a proper understanding of the principles behind correct time delay settings is essential for the best results. In this guide, we explain the principles behind time delay settings in surround sound and show you how to adjust your surround processor or AV receiver for the best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels between the different channels in multi-channel audio, while crucial, are not enough to sustain a unified soundfield in a surround sound setup. A correctly set surround sound system requires that sound from all the different speakers reach the listener at exactly the same instant. This explains why all fronts, left, right and center channel speakers, should be set at exactly the same distance from the listening position. At the same time, in a typical home theater setup, the surround speakers are closer to the viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems apply a split-second delay to the surround sound channels. ----------------------------
its working in 2.1ch mode now...if you have a 5.1ch sound card then your settings on your pc must be wrong. go to playing devices and check the settings in configurations. if its in stereo then change to 5.1 surround.
if you're not using a sound card then check if your motherboard can handle 5.1ch audio otherwise you'll need a sound card.
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Make sure the rear and/or center/sub audio cable is plugged in to
the correct port. On most surround sound cards, the rear audio port is
black, the front audio port is green, and the center/sub audio port is
orange. If you do not have a surround sound card, make sure you obtain
the proper adapter (discussed in the next paragraph) or use surround
sound emulation if your speaker system offers it. If you are not sure
if you have a surround sound card, please check with the manufacturer
of your sound card for details.
Make sure your sound card supports the same amount of channels as
your speaker system contains. For 4.1 systems, it should have a front
and rear speaker jack on the card. For 5.1 systems, the card should
have a front, rear, and center/sub, output. The card should be properly
installed and configured. Please contact your sound card manufacturer
for details. If you do not have a surround sound capable sound card,
you can use the M3D button on the controller unit (if you own a z-560
or z-540) or use the source selector switch (if you own a z-5300 or
x-620). If you do not have any of the models above, you can use an
adapter to split the signal for the front and rear speakers. This type
of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase
this adapter at your local electronic store. Please refer to your
manual if you do not know if your speaker system can emulate surround
sound.
hey bud i would love to try and help! please provide more info on what"htr" home theater reciever, you have the kind of speakers and what ohm or size setting you have and the gauge wire this all make's the diff 5.1, 6.1, 7.1,surround? also call the manufacture yam,onk?,denon,pioneer, there sight's have layouts for wireing avalible and are pretty good lol pete.e n.j.
The solution I found which seems to work is to go into Activity Monitor, and quit "coreaudiod". This forces it to restart and rescan for audio stuffs which makes it work.
This may be in the sound card settings itself.
Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround.
Some sound cards do not support 4 speakers or surround sound systems.
Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
