SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
SOURCE: how do I replace the clutch cable on my honda self
I fixed the drive cable just yesterday. If the model is exactly hrx217hxa with the serial number between MAGA–1000001 and 139999 as mine is, it can be quite involved to replace the cable if this is the first time, because honda wants to replace the "control arm" as well. You can find a detailed instruction to replace the drive cable from the following link.
http://www.lawnsite.com/showthread.php?t=281234
The part number that you need to order is 06225-VH7-305, which comes with a very brief instruction on how to replace based on the service manual (not the user manual). The above link will guide you to how to replace the cable, but since the transmission end of the cable changed, you need to replace the "control arm" as well. This requires to disengage the drive "belt", which is the first challenge. Once you disengage it, it is relatively straight forward to replace the "control arm" if you have the right tools (1/8" pin punch and a challen lock plier which are described in the instruction that came with the cable kit).
Engaging the drive belt back on is the biggest challenge in the whole process, unless you have the right tool to handle the powerful spring that pulls the whole transmission to give friction to the drive belt. I spent two hours to try to engage the belt without the right tool (probably you need a "brake spring tool"), and I finally did it.
The rest of the assembly process is straight forward if you memorize what you did for disassembly. The above link can help you as well.
I took pictures of every step, and am going to post it somewhere soon, but if you want to replace it soon, please send me a message if you need help.
