Question about John Deere Garden
Lawn mower self propelled cable
Hi I have a JS 38 john deere lawn mower. I have had to replace the self propelling cable. The cable I am replacing it with seems too long and no one seems to have the proper cable for my mower. Where can I get one? or is there some way to fix the problem with the cable I currently have ?
DocZachary
    Master:
  • 533 Answers
John Deere Model JS38 Walk Behind Mower Parts
About half way down the page, left hand side. About $20.
Semper Fi,
Z
Posted on Feb 13, 2018
5 Related Answers
tj4ndirish
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
dewey wyatt
  • 202 Answers
SOURCE: Self Propelled mower quit self propelling
you probaly have a broken gear or engagment lever. the part the cable goes through before the cable goes thru the deck. you also could have sheared a pin or the plastic gear that drives it.
Posted on Jul 06, 2009
Anonymous
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
molanne77
  • 7 Answers
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
vincob
vince janis
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
I own a John Deere JS28 self propelled walk behind mower. I have replaced the air filter element, fuel filter and replaced engine oil. The mower is only operating at 60 percent throttle speed.
Hi Jeff:
I'd:
- check the muffler to make sure it has not carbonned up
- check the throttle linkage to make sure it is opening fully
- check the governor and throttle linkage on the carb to make sure it is not gummed up and sticking.
- check the flywheel/crankshaft key to make sure it is not partially sheared.
Hope this helps.
Cheers
Jul 24, 2016 | John Deere Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
John deere gcv160 self propelled wheels not working
The cogs behind the wheels may be blocked with grass. It may also be on the self propelled belt above the blade.
Jun 21, 2013 | Husqvarna Garden
John Deere JS-35 self-propel will not engage now. Help!
Check under the cover of the self propel unit to see if the belt is off the bearing or broken.
Feb 04, 2018 | Garden
Hi, I have a JS63C self propelled push mower that is having trouble with the self proppelled device. At the first speed 1 you can feel some self propell. However, if you advance to speed 2 or speed 3 you...
Hi Jerry. Sounds like your transmission cable needs to be adjusted. Since 1st gear is easiest for it to move in, you probably have little pressure on the clutch. Take the cover off the back of the mower (Torx T25 or T30 can't remember at the moment.) The spring on the cable should be measured when relaxed (handle not being held) then when you squeeze the S/P handle, it should stretch the spring 10mm. A friend or a clamp will make holding the handle and measuring more simple. Adjust the bracket the cable clips into in front of the tranny to obtain the desired 10mm, and you should be under power again.
Jun 03, 2011 | John Deere Garden
The mower will not self propell. could it be that the belt is worn out? Or do I have a bigger problem? If so what should I look for? Thanks, John
Hi john, yes your belt could be cracked and not tight enough to run the drive. Also check your cable adjustment to be sure it is right.
May 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
215 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
