Question about John Deere Garden
L100 John Deere mower will not engage...belt seems very loose but in good condition.
L100 John Deere mower will not engage. Was mowing lawn and went to re engage mower and nothing?? The lever to engage the mower has no resistance to it where before it did. The belt is in tact and looks good but is very loose. I tightened it and cleaned out any debris but still no luck. Any ideas? Is the lever that engages it purely mechanical?
Posted by Susan Jewell on
  • Clyde Ottaway Oct 10, 2017
    check for the belt slipping a pulley
Wade Mobley
  • 513 Answers
L100 has a tension spring on them it may have broke or came off. If i can help any further you may call me and i will help you. I worked for john deere for several years. (831)578-4034 thanks wade
Posted on Oct 12, 2017
5 Related Answers
Anonymous
  • 226 Answers
SOURCE: Engine starts and runs Great. When I engage the
at the point of lowering the pto it's trying tosuck more air to mix with the gas .you might just need to change the air filter.
Posted on Jun 07, 2009
Anonymous
  • 69 Answers
SOURCE: i have a f725 john deere mower and the mower has
Sounds like you may have a safety switch shutting down the PTO. Check them all as there may be a loose connection.
Posted on May 06, 2009
mmarsh69
  • 61 Answers
SOURCE: pto clutch will not engage
ck fuses, and switch, for 12 volts
Posted on Sep 07, 2009
mickey813
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
agent91
Ned White
  • 2100 Answers
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
Posted on Jun 10, 2010
Blades won't engage on John Deere x540.
I would remove the PTO switch and have a Deere dealer test it. Also on the 500 series the PTO operates through the ignition control module which is under the dash, you can see it when you raise the hood. It is black and about 2" wide x 3" long and 1" thick.
Jul 29, 2017 | John Deere Garden
John deere lawn mower
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
JOHN DEERE L100 L110 L120 L130 LAWN TRACTOR SERVICE TECHNICAL MANUAL TM2026
Mar 19, 2017 | John Deere Garden
GOOD MORNING, I HAVE A D140 JOHN DEERE LAWN MOW,IT RUN WELL WHEN NOT MOWING BUT WHEN ENGAGED IT SLOW DOWN AS THOUGH IT HAS TO CATCH IT'S BREATH LESS THAN THREE YEARS OLD
Make sure there isn't anything binding the deck belt or blades. Check the spindles for free movenent. If all that is good then it might be the linkage that is supposed to adjust the throttle when the engine is under load or it might be a carb issue...especially if you run ethanol gas in it.
Aug 27, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
John deere lawn tractor
The most likely problem is that the drover presence switch under the seat is not working.
26264769-eflkxg54se0tscyxmrzf5rva-3-2.jpg Hope this helps?
Aug 22, 2016 | John Deere L100 Series
John deere 325
could be a couple of things... fuse? switches? bad clutch?
Sep 07, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
John deere shuts off when mowing
sounds like you have sensor gone wrong.try to check what sensor you use thru your manual
Jul 17, 2014 | John Deere 1966 110 Lawn Tractor 7 Sprayer...
The tractor has a cable connection and a tension spring that may have broken or has came off. It's hard to say for sure without seeing the mower or guiding someone over the phone as they are looking at things. If i can help further you or someone may call me at (831)578-4034 i live in California our time zone my be different.
Oct 10, 2017 | John Deere Garden
Garden Logo
2,214 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
