Televison & Video Logo
Lashan Mahone Posted on Jun 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced projection lamp in panasonic multi media projection television and reset timer t_v played for a day or so then cut it off now power will not come back on green light is blinking on power
rostit
Level 3:
  • Panasonic Master 746 Answers
  • Posted on Jun 03, 2015
rostit
Panasonic Master
Level 3:
Answers
746
Questions
0
Helped
202238
Points
2851
Make sure the Lamp door is tight. Unplug the TV, and remove the lamp and then reinstall the lamp making sure the door is tight. Then plug the TV in and try again. If it does not work, please post the model # of the TV.
  • 1 more comment
  • Lashan Mahone Jun 03, 2015
    no it is still not working the model number is this may also means something buttons on the remote controlI also blinking from time to time
    model numberPT-52LCX65
  • rostit Jun 06, 2015
    It is starting to sound like it might be a fan. However, there is something you can look at. Here is the manual for the TV. Please look at page 65 and see what the indicators lights are telling you. The lights will flash in a certain pattern. We need to know that pattern
    http://service.us.panasonic.com/OPERMANP...
5 Related Answers
Anonymous
  • 1153 Answers
  • Posted on Dec 17, 2007
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Anonymous
  • 18 Answers
  • Posted on Jan 05, 2008
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Anonymous
  • 80 Answers
  • Posted on May 31, 2009
SOURCE: power was off
You need to replace 4 capacitors on the DM board. It is located inside a metal box on the left side of the set, looking from the rear. The original parts are 1000uf 16v. You will need to install 1000uf 25v or 35v. They are located at the top of the board and are green colored.
Anonymous
  • Posted on Feb 27, 2010
SOURCE: projection lamp timer reset
The others are almost right. You first hold down the minus button on your "TV", then at the same time hold down 0 on your remote. Make sure if you have a universal remote to swich it to TV.
Anonymous
  • 416 Answers
  • Posted on Mar 18, 2010
SOURCE: How do we reset the lamp timer?
Try holding down VOL - on the TV panel and then hold SPLIT or PIP on the remote for 5 seconds. A message should appear saying it is reset. I hope this helps.
1helpful
How to reset tv lamp on mitsubishi wd-65831
RESET LAMP TIMER
    • 1 Turn on the television after replacing your television's projection lamp with a new unit. If a dialog box displays on the screen asking you to reset the lamp timer, use your remote control's "Arrow" buttons, highlight "Yes" and press "Enter." If the dialog box does not appear on your screen after turning your television on, proceed to the next steps.
    • 2 Turn on the television, then press the "Menu" button on your control. Navigate to the "Setup" menu, press "Enter" and choose "Low Powericon1.png" from the menu options displayed on the screen. Press the "Exit" button on your remote control and turn off the television.
    • 3 Repeat the first step to reset your television's lamp timer. If your television screen is unable to produce a picture after replacing the projection lamp, press the "<", ">" and "Power" buttons on your remote control at the same timeicon1.png to reset the lamp timer.
Read more: http://www.ehow.com/how_7358147_reset-lamp-timer-mitsubishi-65731.html#ixzz33n0pJu2S
tip
Panasonic PT-52LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation instruction guide here.
I hope that helps.
Can I reset the lamp timer without the original remote
No, original remote is needed for this--a universal will not cut it.
If Panasonic the remotes are usually reasonably priced and have all the features you really need.
11helpful
2answers
How to reset the lamp timer?
Here is a link to replacing the lamp and the instructions for resetting the timer.
Just search for your set on the page.
I hope that this helps you.
asnowman
http://911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
1helpful
I NEED TO RESET LAMP TIMER PANASONIC PT52LCX66.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV. Follow these steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
2helpful
LP 50 Panasonic Projection TV just replaced the lamp but don't know how to reset lamp clock
Panasonic Lamp timer reset.
To reset the lamp timer
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
asnowman
2helpful
For about 4 weeks in have been getting a notice when I turn the tv on about a lamp timer needed to be reset. While the TV was on it cut off by itself. This is a panasonic 43" rear projection LCD TV. It is...
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
This is the procedure for resetting the lamp timer. Have you ever replaced the lamp before? The lamps usually never last 5yrs.
Replaced bulb,still not turning on-power flashes green then red and lamp light comes on
Did you reset the lamp timer? If you replace the lamp and dont reset the lamp timer the TV will continue to display the lamp error until you do.
2helpful
Reser timer for lamp
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
