Spark plugs is black and i think it is running rich mixture. how to adjust mixture properly to get gray and tan color?
If it's running well, I'd put in fresh plugs and then try to "tune" it.
With the engine running at low to mid RPM lean it out until the revs increase, and then drop. Back off on the adjust until the RPM peak, then another 1/3 turn. Run for 5 to 10 minutes. Let lool, check spark plug for desired colour.
Testimonial: "its worked. thank you."
SOURCE: flooding problem need to adjust mixture screw to correct setting
is air filter clean and what is your elevation?
SOURCE: what causes plark plugs to foul,they keep turning
Plugs foul for a couple reasons, engine in poor condition (worn rings - poor compression), wrong oil, wrong plugs, bad riding conditions, cheap fuel, out of tune, carb out of tune.
You are not mixing your fuel with oil are you?
You might need a carb tune up (Id start by adding some injector cleaner to the fuel according to the bottle instructions.
You might put a hotter plug in your engine, one or two range increase.
If you will go to a good auto parts store, they will probably have a chart of assorted plug conditions and their cause. The counter man may be able to make a recommendation to you.
SOURCE: is sputtering and backfiring but from carb. its
You need to clean the carb not adjust it.(unless you already have)The jet can become stoped with trash,or the float could be dealing with debris.remove the bowl clean the parts and try again to run it.Just putting cleaner in the fuel will not remove dirt, bugs, or other trash from inside carb.
SOURCE: air fuel mixture adjustment 04 honda 125 innova anf
the jetting should not be a problem, perhaps the air cleaner element is dirty or the element even if it looks ok sometimes needs a new one, the smaller motors often rely on the right intake vacumn through the filter for the carbs to work as designed
Testimonial: "yeah i did that and it made an instant difference.thanks again fixya. des obrien"
SOURCE: Fuel/air mixture screw. How many turns should the
3.5 turns out should fix it. Hope this helps.
