Hello. I hope someone can help me. The fog light switch will not light up and fog lights don't work. Is there a fuse box I need to check and where can I find it? what fuse? if any. It's a 2002 Miata
Well, the problem is that I dont know the reason, you should investigate. There could be issues with lamps (must get new) or electricity problems (must head to auto-service)
Well there is a fuse for your fog lights. I don't have the make year or model so I can't say where but there is a fuse. More than likely in the under the dash fuse panel. If your having trouble finding the fuse you can still check to see if it is the bulbs. Swap a working bulb with a suspected bad bulb and see if it lights up. If both are out then find that fuse and see if it is blown. Might be your fog light switch too.
Regards,
Tony
Check your instructions with the fog lamps, I believe you will need to take your car to a dealer to have them activate the fog lamp driver in the Totally Integrated Power Module.
the key must be on and the headlight need to be on low beam for them to operate,your dash button for the fog lights should have a small light in the switch when you have all the above on,if there is no light in the switch,check your owners manual in the glove box,it will show you fuse box locations and what each fuse feeds
Check the relay to the fog light, it's the fuse and relay box under the hood behind the battery. Take the relay out labeled fog light and switch it with an other relay for now just to see if it is the relay, it the fog light's work then it's the relay. If they don't work then it's the switch, good luck and hope this helps. Keep me posted, be glad to help.
