Myryad Z Series Z140 Amplifier Logo
A
Anonymous Posted on May 09, 2015
Need circuit diagram / schematic - Myryad Z Series Z140 Amplifier
Audio Service Clinic
Level 3:
  • Myryad Master 924 Answers
  • Posted on Jun 23, 2015
Myryad Master
Level 3:
Answers
924
Questions
Helped
351463
Points
1710
Need more information.
Schematic?
A schematic, or schematic diagram, is a representation of the elements of a system using abstract, graphic symbols rather than realistic pictures. A schematic usually omits all details that are not relevant to the information the schematic is intended to convey, and may add unrealistic elements that aid comprehension. For example, a subway map intended for riders may represent a subway station with a dot; the dot doesn't resemble the actual station at all but gives the viewer information without unnecessary visual clutter. A schematic diagram of a chemical process uses symbols to represent the vessels, piping, valves, pumps, and other equipment of the system, emphasizing their interconnection paths and suppressing physical details. In an electronic circuit diagram, the layout of the symbols may not resemble the layout in the circuit. In the schematic diagram, the symbolic elements are arranged to be more easily interpreted by the viewer.
Schematics and other types of diagrams, e.g.,
Transit map, a schematic map (i.e. not drawn to scale, stations are equidistant, lines are drawn at 45 and 90-degree angles)
Schematic of a drive train
Chemical engineering schematic
exploded view of a 3D-engineering drawing
Zoom Guitar Processor G2.1u does not switch on. Need the circuit diagram/schematic
Try a different adapter first before digging into it. Check voltage and amperage on the adapter. Chances are that is the issue.
37helpful
10answers
TV Circuit board diagram
My SONY TV Model : KV-XJ29M50. LED will blink/flash twice right after power turn on and cannot display picture.
9helpful
7answers
Need tv schematic diagram
Post the model number of the set youre needing schematics for and I can post a link where you can get the service manual with schematics.
Need schematic diagram, some advice and ultimately replacement parts
You have something in short circuit in power supply pattern, so filter coils are burnt. It may be voltage regulator, or regulating transistor, electrolytic capacitor or even shorted diode at pwr. input serving to protect in case of inverse polarity applied. Check all for short. Was it reverse polarity or overvoltage occured?
Mladen,
[email protected]
Top Myryad Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Myryad Audio Player and Recorder Expert? Answer questions, earn points and help others
