2006 Suzuki Grand Vitara Logo
Bonnie Young Posted on Apr 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the 60A primary fuse located? - 2006 Suzuki Grand Vitara
paulmacintyre
Level 3:
  • Suzuki Master 3,218 Answers
  • Posted on Apr 12, 2015
paulmacintyre
Suzuki Master
Level 3:
Answers
3218
Questions
0
Helped
968529
Points
11418
It can be a metal fuse located close to the battery cables or a plastic fuse located in he underhood fuse/relay center. Check owners manual for fuse locations and identifacation
Where is my ABS fuse located on my 2000 Silverado
2 WD or 4X4 ? Don't know if that would make a difference .
BRAKE Fuse #3
10A
Electronic Brake Control Module (EBCM) Fuse Block
On the lower left side of the IP
ABS Fuse #2
60A
Brake Pressure Modulator Valve (Pump) Engine Wiring Harness Junction Block
At the left side of the engine compartment near the battery
1helpful
I have a 1995 Toyota RAV4 and would like to know about the fuse ABS 60A as I am missing this fuse.
ABS labeled fuses of this era Toyota are for ABS (anti-lock) brakes.
It shouldn't hurt to replace it, but the anti-lock may not be working correctly is why someone removed it. The anti-lock may sense incorrectly and engage when it's not needed.
Which relay/fuse controls the power windows?
Visual Inspection Chart Mechanical Electrical
  • Door window regulator and motor
  • Door glass top run
  • Door window glass
  • Loose, corroded connectors
  • Circuitry
  • Window control switch
  • Battery junction box (BJB) fuse(s):
    • 1 (60A)
    • 3 (60A)
    • 11 (50A)
  • Smart junction box (SJB) fuse(s):
    • 7 (20A)
    • 27 (10A)
    • 30 (10A)
  • SJB circuit breaker 10 (30A)
  • SJB rear window defrost relay 1
  • Relay center box 1 rear window defrost relay 2
  • Delayed accessory relay
  • Battery saver relay
  • Rear window defrost grid
Where is the Power Windows Fuse in a 2005 Ford Taurus?
It is located in the SJB smart junction box , it's a fuse / relay center / microprocessor ! Fuse # F2.10 30 amp . location -behind left side dash panel . Also check the accessory relay . Top relay left side , same location SJB .
  • Door window glass
  • Circuitry
    • 1 (60A)
    • 3 (60A)
    • 11 (50A)
    • 7 (20A)
    • 27 (10A)
    • 30 (10A)
Alternater good but not charging
Did you check your fuses. There are several charging fuses that you need to change. Engine compartment left fuse location (7) 20A, alt sensing fuse (11) 7.5, right side alt fuse (8) 60A
I have a 2006 Chevy HHR. My son jumped his car with it and my power steering quit. I can't find the owners manual and don't know where the fuse is located to check it. Could you help please?
Under the hood, on the Driver's side is the main fuse box. EPS fuse is #1 and is a 60A. Also, there is another 2A fuse located in the small fusebox on the inside, passenger side on the console (near firewall).
Usually, it is the 60A that is blown.
7helpful
I need a diagram of the underhood fuse block for my 2002 ford explorer. I don't have an owners manual.
Fuse/Relay Location*Fuse Amp Rating* Description
1 60A** PJB 2 30A** BSM 3 20A** Not used (Spare)
4 30A** Rear defrost 5 40A** ABS (pump)
6 60A** Delayed accessory circuit breaker
7 20A** Power point #2 8 — Not used 9 20A** Power point #1
10 30A** ABS module (valves) 11 40A** PTEC
12 50A** Ignition relay/Starter relay
13 40A** Trailer tow battery, Trailer tow turn signals
14 10A* Foglamps 15 15A* Memory (KAPWR)
16 15A* Headlamp switch 17 20A* 4x4 (v-batt 2)
18 20A* 4x4 (v-batt 1) 19 20A** High beam relay
20 30A** Electric brake 21 30A** Front wiper motor
22 20A** Autolamp; Low beam 23 30A** Ignition switch
24 20A* Rear Fog Lamps 25 – Not used
26 15A* Fuel pump 27 20A* Trailer tow lamps
28 20A* Horn relay 29 60A** PJB 30 20A** Rear wiper motor
31 — Not used 32 — Not used 33 30A** Auxiliary blower motor 34 30A** Power seats, Adjustable pedals
35 20A** Rear power point 36 40A** Blower motor
37 15A* A/C clutch relay/Transmission
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Suzuki Expert? Answer questions, earn points and help others
