These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
SOURCE: 6 slow and 1 fast blink on a Philips 60pp9200d/37 Thanks.
These blink code is fault indication. With Philips brand TVs, we cannot read these blinks as they appear. Means by digits. There is a special procedure to read these blinks. If you wish to get more details about the blinking codes reading procedure to Philips TVs, visit this site. Pull up older posts there. Details are given about how to read these blinks and convert them to numerical digits.
Check the site with patience. It has so many posts, and all are related to electronic equipment repair. Check it in 'Timeslide' option. It will be easy to find brands.
