Computers & Internet Logo
a
andrew marshall Posted on Mar 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I factory reset my rct6103w46 and it goes strate to a settings password
Ray Savellano
Level 2:
Sergeant:
  • Expert 324 Answers
  • Posted on Mar 11, 2015
Ray Savellano
Expert
Level 2:
Sergeant:
Answers
324
Questions
Helped
58986
Points
727
It's looking for the default password.
Reset sharp 14v w150 m password
Resetting the password on a Sharp 14V-W150M projector can be a bit tricky, as the process may vary depending on the specific model and software version. Here are a few steps you can try to reset the password:
  1. Check the manual: The first step is to check the manual that came with the projector. It may have instructions on how to reset the password.
  2. Use the default password: Some Sharp projectors have a default password that can be used to reset the password. The default password is often "admin" or "password". If you're unable to find the default password in the manual, you can try searching the internet for it.
  3. Contact Sharp support: If you're unable to reset the password using the steps above, you may need to contact Sharp support for assistance. They may be able to provide you with a reset code or assist you with the process.
  4. Factory reset: If all else fails, you may need to perform a factory reset on the projector. This will erase all settings and restore the projector to its original factory settings, including the password. The factory reset process may vary depending on the projector model, so it's best to consult the manual or contact Sharp support for specific instructions.
It's important to note that a factory reset will erase all settings and restore the projector to its original factory settings, including the password, so it's best to have a backup of all important settings. It's also important to note that attempting to reset the password can be tricky and if you're not comfortable with this task, it's best to consult a professional technician or Sharp support for assistance.if i was able to help my cashapp $ralphpapi thank you have a blessing day
I have a 10" RCA tablet RCT6103W46. I have lost google play services and google play, my gmail is not frozen
try to type in google in the browser bar to get it back or you will have to go in setting and factory reset the tablet
Why cant i update or upgrade my rct6103w46 rca tablet
make sure the account you are using is good, check settings on your tablet. check storage if you got room, delete your store and load up again, last reset it or after back up factory reset it. Good luck
My RCA tablet model#RCT6293w23 locked out of tablet due to a virus/scam cannot access anything on tablet how do Ifactory reset when I can't use the settings or access any part of the tablet
You must then do a factory reset using the Power and Volume
Buttons.
Here is a good link that tells and shows how to do it:
http://www.rcatablets.com/how-completely-reset-your-rca-rct6103w46-android-422-tablet
The model number is not the same but it should work anyhow.
There is a typo in Step 1, however so do this instead:
With the tablet turned OFF (not sleep but OFF) press and hold down at the same time both the Volume(-) button and the Power button. Continue to hold both of them down until you get a screen with the Android Robot, and or green text. That should set you up to follow the instructions.
Good luck.
My RCA Tablat will not reset to factory setings even when push reset on rhe back of the device.
thers likely a sequence to it such as turn it off then press the reset while keeping it pressed then start up the tablet or long press the reset for 30 seconds or some other sequence, best to check the instructions for it if you can this is a link to a manual hopfully this will help, in the reset section it says hold in reset for 8 seconds, sounds quite speciface so time it accurately, good luck.http://www.rcatablets.com/sites/default/files/RCT6103W46%20IB%20English.pdf
2helpful
2answers
I forgot my password to my rct6103w46
try this one How to Completely Reset Your RCA RCT6103W46 Android 4.2.2 Tablet Follow the detailed instructions below on how to completely reset your RCA RCT6103W46 Android 4.2.2 tablet.
Step 1. With your tablet turned off, press and hold the volume down (-) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.
Step 2. Next, press the volume up (+) button. You should then see the screen below.
Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.
Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.
Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.
[img alt="" src="http://www.rcatablets.com/sites/default/files/step5_4.2.2.png" >6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished. Congratulations, you have successfully reset your RCA Android 4.2.2 tablet.
goodluck
1helpful
Reverted to factory default, typed in router name and wap password, but cannot acces, it goes to dlink
you need to reconfigure the wireless settings since you reset your router to factory defaults.
login to your router with admin/admin as the login/password
click on wireless settings and enable wireless security mode to wpa and type in the wireless password you wish to setup.
all wireless devices will need to be setup to your new router settings.
I have lost the username/password pair for the Linksys ProConnect II PC22604. How can I reset to factory defaults. If someone has the .rom configuration file that this unit will export (and the UN/PW...
Hi this works on a netgear router you could try this on you Linsky or the hair pin
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
2helpful
2answers
Password forgotten
There is a reset button on the back of the router, usually has the words RESET next to it and you have to use a sharpened pencil or a paperclip to push it. Press and hold that button for one minute. Do not let go. After you release it the lights blink and then become steady.
Now you have reset your password to it's original factory default.
Your wireless router default settings are:
192.168.1.1
username: admin
password: password
From this point on, you can re-set up your wireless router. To do so you connect your computer to a LAN port on the router.
Open internet explorer or firefox (whichever you use) and type into the address bar: 192.168.1.1
Login with the username and password.
From here on you can change your SSID, username, password, set wireless security, and so on.
Good luck, let me know how it goes.
Please don't forget to give me a vote and feedback.
I forgot the password to my phone after I changed it. How do I fix it since I can't get on the actual phone to reset the password. ??
I didn't know if this codes will work on your phone as that phone is new, but let me remind you that it will somehow lose your settings once successful factory reset has been done. you can try the code if you choose to reset it to factory setting and if you think that it is the last resort to your problem.
Try without sim : if it goes to offline mode
type the codes you may choose how to do it.
2945#*# and chose Factory Reset ...
47328545454 # or
2945#*88110# and factory reset codes
good luck
Grand Canyon Tech
Grand Canyon Tech
