Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Can,t prime fuel with primer ball on my weed eater XT 400, lots of fuel and lines look good
Posted by dc_coulombe on
nathan
  • 634 Answers
Sounds like it has gotten dirt in it, flush lines and tank with brake cleaner, remove primer bulb usually 4 screws and clean under there too reassemble and try again fixes most of the time
Posted on Jul 08, 2009
Anonymous
    Problem Solver:
  • 17 Answers
Be sure the line in the tank did not disconnect. that would cause you to pump all you want but never get a drop.
I have a troybuilt weed eater. I just put a new carbeutor on and its not running right. It has compression but will not start?
check the position of the fuel lines to the primer or if part of the carby from the tank to the carby
the way it works is that the primer bulb sucks fuel through the carby to prime it so the tank line goes to the carby and the line from the primer back to the tank
could be flooded or the metering screws have to be adjusted
Jul 22, 2017 | Garden
My weed eater won't prime
check the primer bulb to be sure it is not cracked. check the fuel lines also. they crack and wont pull fuel.
Jun 15, 2017 | Garden
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Troy built 90bc weed eater will not prime after new fuel lines
Could there be the possibility that the lines may of been put on the wrong way i would try swap them around first, also the primer bulbs do not like air make sure all the fuel lines are all on tight and that there is heaps of fuel in the tank
Jul 30, 2014 | Garden
What else should i try
Make sure lines are connected correctly. On the back of primer it is stamped In & out
Jul 25, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
change the fuel lines over on the carby
you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
Mar 12, 2017 | Garden
Troy-Bilt weed eater, Model TB90BC, had rotten fuel lines and primer bulb, I replaced but may have hooked them up wrong. How do I hook them up?
Prime and watch the fuel move up to the carb. This is the fuel line and it should be long. Make sure it goes to the bottom of the fuel tank.
Apr 04, 2010 | Troy -Bilt String Trimmer/Blower...
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
1,396 people viewed this question
Top Poulan Garden Experts
dannydoesita
Marvin
Marvin
bryan st
Are you a Poulan Garden Expert? Answer questions, earn points and help others
