When mine does that , it just needs the "Stop/Clear" switch to be pressed a few times.
If that's not the problem, I assume you've checked the wall outlet for proper voltage. I usually plug a small desk lamp in the same outlet.
Hope this helps.
First, check to see if the circuit breaker has tripped. Then check to make sure it is firmly plugged in to the outlet. After that, it is time for a technician.
