Will not drain
SOURCE: GE Profile Dishwasher not draining
HI,
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
A
clog in the drain line or air gap (if there is one) is the usual reason
that a dishwasher won't drain. Often the problem is at the point where
the drain line attaches to the garbage disposer or household drain
line. If you remove this line, you can clear any debris from the hose
or hose connection. Be sure to reattach the hose before starting the
dishwasher again.
Pump
Your
dishwasher pump ejects the water. The pump is usually mounted directly
to the motor, then attached to the bottom of the dishwasher. You can
reach the pump from inside the dishwasher, but first you need to remove
the lower rack, the spray arm, and the spray arm support.
Look
for an impeller--a round plastic fan blade-type of device that spins
around. This is the wash impeller, which forces the water through the
spray arm. Beneath the wash impeller is the drain impeller, which is
similar in size and shape to the wash impeller. The drain impeller
pushes the water toward the drain port. These components make up the
pump. If any of the pump components are defective, you need to replace
them.
Drain valve and/or solenoid
Many
dishwashers use a drain valve with an electric solenoid. When
electricity flows to the solenoid, the valve opens and diverts the
water to the drain. Sometimes the solenoid, or the diverting lever,
sticks and prevents the dishwasher from draining or filling properly.
Try to free up the solenoid to lubricate the lever. Otherwise, you may
have to replace the solenoid or pump assembly. With these systems, the
motor always rotates in one direction. When it's energized, the drain
valve diverts the water.
Other dishwashers simply reverse the
direction of the motor to drain the dishwasher. These units don't have
a drain valve. Instead, there's a drain hose connected directly to the
pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If
the motor isn't turning or working, the unit won't drain. First check
to be sure you have power to the dishwasher. If not, see the section
"It doesn't work at all." If the motor hums but doesn't turn, it may
need to be replaced.
Some dishwashers are susceptible to
getting stuck if you don't run them regularly. If you haven't run the
dishwasher for more than a week, you may need to manually spin the
motor to free it up. If the motor is defective, you need to replace it.
Dishwasher motors can't be serviced.
Timer
Part
of what the timer does is control the motor and drain valve. If the
timer doesn't work properly, the water may not drain and you need to
replace the timer. This problem is uncommon.
SOURCE: GE Profile Dishwasher with water in bottom, won't drain
I have the same dishwasher and encountered the same problem last year. What I had to do was call a plumber out. But all he did was clean out a plastic compartment in the bottom of the dishwasher then turned on the garbage disposal for a few minutes. There was some larger debris under the plastic compartment and the problem was solved. I am however now experiening a different problem w it. Good luck!
Sandi S
Lexington KY
SOURCE: purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The
purge routine operates the bulk dispenser pump continuously to drain
the bulk dispenser tank when an incorrect liquid was poured in the
tank. The process consists of setting up the dishwasher to run the
purge mode, running the purge mode and then cleaning up the purged
detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
SOURCE: my ge Profile dishwasher will not drain
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).....
SOURCE: GE Profile Dishwasher does not drain. model #
I had a similar problem with a GE GSD5811 model. The hoses were clear, and the auxiliary pump worked fine. It turns out that it was the "piston" assembly that had basically disintegrated over time. This part diverts water to the pump during the drain cycle.
To check it, remove the mesh filter at the rear of the inside of the machine, by carefully unclipping the heater element from the back of the machine and removing the 4 hex-head screws securing the filter panel.) Unscrew the piston assembly from the tub, and pull it out. If the sealing plunger has deteriorated or is jammed, replace it. The part number for the "piston and nut assembly" for my machine (and probably numerous others) is WD24X10018. It should cost anywhere between $10 and 16, depending on where you shop.
Another possibility is a bad drain solenoid. (This is what actually triggers the piston assembly during the drain cycles.)
Here
is a tip that I wrote that will help you with your dishwasher not
draining problem...
Dishwasher Problems - Water
will not drain
out
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
Dishwasher
Residue and Film on Dishes
heatman101
