PDP AFTERGLOW AP.2 Blue Wireless Controller for PS3 Logo
A
Anonymous Posted on Feb 14, 2015
My Afterglow Ap.2 ps3 controller turns off randomly during gameplay. How do I fix?
When it is connected by usb cable it works fine. When I take the cable off, it turns off randomly during gameplay.
xIFelix
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 182 Answers
  • Posted on Feb 22, 2015
xIFelix
Expert
Level 2:
Mentor:
Answers
182
Questions
0
Helped
7519
Points
271
It's quite possible that the controller is faulty...Xbox One controllers are actually having the same issue as well. Normally speaking you can either contact your manufacturer about an inquiry to get it sent in for repair, or you'll have to go out and get a new one. If they don't have a fix for you, that's one of your final options.
How do I connect the Afterglow Controller to my Sony PS3 when the controller doesn't have a USB port on it?
Question edited for clarity.
Question moved from Computers to PS3.
The controller is wireless and connects to the PS3 using the USB Dongle that plugs into the USB Port on the PS3.
How do I pair my Afterglow Wireless controller to my USB dongle?
  1. Plug the new USB dongle into your PS3.
  2. Now, press and hold the Home button (power button) on the controller until the LED on the USB dongle and the 4 indicator LED's on the controller are solid.
Jun 2, 2021
Afterglow PS3 Wireless Controller User Guide - PDP Support
How do I get my PS3 afterglow controller with a chargeable battery installed to connect to my PS3 system. (afterglow controlder does not take AA batteries).
Afterglow AP 2 has a flat nickle battery
upgrade your controller
i take it yours is not a wireless
PS3 wireless afterglow controller uses aa rechargable
Afterglow wireless controller. Do I need the dongle to sync it to the Play Station?
Yes. You may be able to get another one but not 100% sure if it will sync to a different dongle. I would guess that it will work. Green Afterglow AP 2 Wireless Controller Receiver Dongle PS3 Playstation 3...
My ap2 controller wont turn on the ps3 but it can turn off?
Try resetting the controller worth a needle or something like it. There is a small reset hole on the back. Good luck
Where is the reset button for the afterglow AP.2 wireless located
There is not one. The Afterglow AP2 requires a dongle that plugs into one of your available USB ports in the system. Without it, it is just a glowing paper weight. Setup: Controller=transmitter, dongle=receiver. Read the box if you have it. If it says something like (2.5 htz) then it isn't bluetooth compatible.
1helpful
2answers
Why wont it connect?
there is a sync button somewhere on the controller and the usb thing you plug into your Ps3, pres those at the same time continuosly put make a 2 second break untill it connects.
Ps3 freezing during gameplay, started after most recent system update, wont recognize disk at times.
You need to RESTORE FILE SYSTEM of your ps3.
Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Good Luck!
Ps3 controller issues
Have you charged the controllers in a while. The controler might just be running out of energy to work.
Top PDP Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a PDP Video Game Console and Game Expert? Answer questions, earn points and help others
