No PC model told. desktop (vast there are)
same on all desktops made
one side of case.
remove 2 cable to drive
remove 4 side screws from side of drive to cage.
remove drive, slides out.
some PCs the drives have caddies.
no PC told
the manual is here
https://www.emachines.com/ec/en/US/content/support.html
SOURCE: need to add hard drive and memory to emachine tower 333
Okay, this is what you do, I don't really think that Win 98 supports dual HDDs, but I think I can help.
If you have a IDE Dual Cable (plug into the Motherboard and have two connectors attached), Do you see the mini plug by the connector on the HDDs? (Usually white or different color) on the Original HDD, put the miniplug to "Master" and the second (added) HDD to "Slave" or you may be able to use the "Select" on both.
What I do recommend though is going ahead and burning all of your precious data to CDs and buying a newer HDD.
Instead of 4 Gigs, get something around 80 Gigs.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2948583&CatId=134
If you give me the motherboard specifications, you may be able to update your RAM to 128-256 MB
SOURCE: how do i remove hard drive from emachine el1300g
Look at these, one should be yours and should help:
HDD pdf 1:
http://web.archive.org/web/20050325222851/http://www.emachines.com/support/download/nexgen2/HDD_a.pdf
HDD pdf 2:
http://web.archive.org/web/20050325215906/http://www.emachines.com/support/download/grey_dt/hdd.pdf
